84 vette. Headlight bezel getting caught on hood
Old Sep 28, 2015 | 01:54 PM
NinjaJ's Avatar
NinjaJ
Cruising
Default 84 vette. Headlight bezel getting caught on hood
So I took my headlight bezel and the motor out and replace the gears in it. Reassemble it back on the car and when I turn on the light switch the bottom of the bezel is getting caught on the hood and won't open. Is there a left or right adjustment on the headlight brackets? I've tried everything I know to get it to move over to the right. Don't need much
Old Sep 28, 2015 | 01:57 PM
antfarmer2's Avatar
antfarmer2
just loosen it back up and ajust
Old Sep 28, 2015 | 01:58 PM
John A. Marker's Avatar
John A. Marker
Passenger or Driver's headlight? If it is the passenger's side, check the coolant lines going to the overflow tank. If they have moved a little, the light will hang up.
There is a small about of left/right adjustment on the brackets that hold the assembly....slots rather than holes. But you will not get much.
Old Sep 28, 2015 | 02:08 PM
NinjaJ's Avatar
NinjaJ
Cruising
passenger side and the hood is up. it's getting caught on the bottom left corner when the light flips up..
Old Sep 28, 2015 | 02:23 PM
John A. Marker
Loosen bolts and move assembly.
Old Sep 28, 2015 | 02:51 PM
NinjaJ's Avatar
NinjaJ
Cruising
Thanks for the replies everybody
Old Sep 28, 2015 | 02:58 PM
antfarmer2's Avatar
antfarmer2
To 84 vette. Headlight bezel getting caught on hood
