Installing 30lb ford injectors on LT1 Question!!!
Old Aug 24, 2002 | 05:09 AM
James94LT1's Avatar
James94LT1
Default Installing 30lb ford injectors on LT1 Question!!!
With the head/cam swap I upgraded to 30lb injectors. It seems like the clip that holds the injectors to the fuel rail won't go on because the groove isn't cut all the way around. Am I missing something here?
I'm getting close and want to get her running tomorrow ( later today )
Old Aug 24, 2002 | 04:19 PM
James94LT1's Avatar
James94LT1
Default Re: Installing 30lb ford injectors on LT1 Question!!! (James94LT1)
Anyone???
Old Aug 24, 2002 | 05:10 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Try the upper groove. I put these on my car without any problems.
Old Aug 24, 2002 | 09:37 PM
James94LT1's Avatar
James94LT1
Default Re: Installing 30lb ford injectors on LT1 Question!!! (AquaMetallic94LT1)
Cool! Thanks Aqua that worked i was just trying to shove it in to far I guess.
Old Aug 25, 2002 | 12:47 AM
The Green Rocket's Avatar
The Green Rocket
When I got my SVO 30# injectors a few years back it didn't seem to matter which groove I tried as the SVO injectors were at that time designed to have the clip install rotated 90 degrees from the way the Corvette is set up. So I just took a dremel and modded the groove for compatability.
Thomas
Old Aug 25, 2002 | 03:23 AM
James94LT1's Avatar
James94LT1
Default Re: Installing 30lb ford injectors on LT1 Question!!! (The Green Rocket)
I went on the top ring and they went right on! Thanks! Car is running! :cheers:
To Installing 30lb ford injectors on LT1 Question!!!
