bad lifter?
Old Oct 8, 2015 | 06:54 PM
tombrammer's Avatar
tombrammer
Default bad lifter?
93 lt1 had valve cover off and noticed one lifter pumping 2x-3x more oil than all the others is this anything to be concerned about? Lifters are about 2yr old ls type.
Old Oct 8, 2015 | 07:40 PM
John A. Marker's Avatar
John A. Marker
Is the lifter noisy? If not, I would just leave it. Your seeing the oil flow at idle I would assume. The oil will flow better to all when the engine starts to move up the RPM range.
Old Oct 8, 2015 | 09:01 PM
tombrammer's Avatar
tombrammer
Yes it's a little noisy but not at idle, it's makes noise from about 1000-1200rpm then it goes away.
To bad lifter?
