Parking Lamp (tail lamp) Problem
Old Oct 9, 2015 | 09:25 AM
joalyons's Avatar
joalyons
Default Parking Lamp (tail lamp) Problem
Yesterday went to drive the Vette (1988) pulled my light switch and the parking/fog lamps didn't light. My first thought was the tail lamp fuse so I checked and it was fine, just to be sure I replaced it anyway but they still didn't work. I put my multimeter on it and there is power to both sides so it's not the fuse. Could my light switch be bad or is there another fuse/relay for the circuit?
Old Oct 9, 2015 | 09:47 AM
WVZR-1's Avatar
WVZR-1
The light switch is NOT fused, it does I believe have an internal circuit breaker. You only mentioned park & fog, you realize FOG is a separate switch?
Do you have headlamps? Your post is a bit confusing as you mention two entirely different functions.
What lamps do you actually have front and rear with the headlamp switch rod pulled to the headlamp function?
Old Oct 10, 2015 | 09:09 AM
joalyons's Avatar
joalyons
Thanks for the reply, I mentioned the fogs just to be clear, guess I wasn't. The only lights that work when I pull the switch are the headlights. Parking lights, tail lamps, side marker and Fog lights do not work. It's as if the Tail lamp fuse is bad but as I stated its not.
Old Oct 10, 2015 | 09:18 AM
WVZR-1's Avatar
WVZR-1
If when the headlamp switch is ON and the FOG is ON and you have NO FOGS then I believe it might be safe to assume you've a lighting switch problem. The balance of your problems indicate this also I believe. Do you have a FSM so that you can use the wiring schematic to check the power to the switch.
Old Oct 10, 2015 | 09:54 AM
joalyons's Avatar
joalyons
I do have an FSM, so thats on the list of things to do today. Thanks I will post the results.
Old Oct 10, 2015 | 08:41 PM
joalyons's Avatar
joalyons
Went thru the steps in the FMS, seems to be he HL switch . I wiggled the HL switch and it works now so Im thinking there is some sort of short in the switch, ordered a new one today,
To Parking Lamp (tail lamp) Problem
