The word "billet" is one of the latest sales buzzzzz words to get you to by things. It just means that this item has been machined from a solid piece of material.
If you want to replace them to dress up the engine, then get something that will also benefit. I would suggest the March Under-drive three piece pulley set.
I agree with John. I am running the march pulley set and it came with the alt, crankshaft, and waterpump pulleys. pretty straight forward install too. You will have to go with a slightly shorter drive belt though annd I am not sure exactly what the size will be but the kit will tell you.
I would scout for used March pulleys Or Summit / Jegs scratch and dent. Save hard earned Money. They are great looking. Less rotational mass. But the C4 UN-fortunatly will not allow you to show off your pulleys. Like a traditional hood.
As a Semi driver I used to drive by the Atlanta and the Ohio Summit parts stores. Yes, of course I had to stop for a look see. They have a pretty large used/return/wrong part area that I would always check through. Always had some sorts of SB pullys on the racks there.
