Brake light trouble
Old Aug 25, 2002 | 12:10 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Brake light trouble
Im having a problem with my brake lights not working , My third brake light does though, Ive replaced all the bulbs, all my other lights work turn signal parking lights etc any suggestions
Old Aug 25, 2002 | 01:19 AM
jfb's Avatar
jfb
Default Re: Brake light trouble (AshleyRL-87Conv)
There is a seperate switch on the brake pedal for the lower stop lights. The lower brake light switch on an 87 has a light blue and orange wire going to it. You can unplug the brake light switch and measure the switch with an ohmeter to see if the switch makes when the brake pedal is pushed. Also, you can jump the brake switch plug to see if your stoplights work.
Check your 20 amp stop/haz fuse with an ohmeter.
[Modified by jfb, 11:20 PM 8/24/2002]
Old Aug 25, 2002 | 01:34 AM
SLEV89's Avatar
SLEV89
if the Tail Light Running Lamps work but the Brake Lights don't, then i'd suspect the Brake Pedal Switch.
it has two separate circuits that are completed when the pedal is pressed
- one for the High Level Lamps (LightBlue cct#20), and one for the Main Brake Lamps (White cct#17). each circuit is supplied from a common 12V source (Orange cct#140)
is there 12Volts on the White wire when pressing the pedal?
do your rear hazards work? (they use the same filiments as the Main Brake Lamps)
if they do, then it's almost certainly the Brake Pedal Switch or it's associated connectors.
if they don't then you may have a faulty Turn/Hazard Switch Assembly, or a bad connection at any of three different connectors between your steering column and the tail lights (but i kinda doubt this)!
at first i though 'ground problem' - but the running lamps share the same ground, and since your running lamps are fine, ground is good.
this info for an '89 - '87 should be very similar, if not the same.
:seeya hope this helps!
Old Aug 25, 2002 | 02:37 PM
RichAshley-Black99
Default Re: Brake light trouble (SLEV89)
Thanks guys Im going out here in a bit to check it out and yes all the other lights work to include the hazards :cheers:
Old Aug 25, 2002 | 07:02 PM
SLEV89's Avatar
SLEV89
:cheers:
minus one point for me - filament :bb
To Brake light trouble
