Marks on the windows
Old Aug 25, 2002 | 06:01 AM
JP's C4's Avatar
JP's C4
Default Marks on the windows
Hi,
I'm Dutch, can't help it..., I own a C4 Convertible now for 2 years and the fever is growing rapidly.
On my left window some scratches appear. Trying to look down the brushes don't look to be in a great state.
My Haynes manual doesn't give any cidea's on how to get even close.
Yes, it's the outside of the window.
Any idea's?
Old Aug 25, 2002 | 06:55 AM
HighHopes85's Avatar
HighHopes85
Default Re: Marks on the windows (JP's C4)
Are you asking how to adjust the window, replace the felt, or remove the scratch? If the scratch is fine enough, you can get it out with #0000 steel wool. This has worked for me since the previous owner apparently rolled his windows up and down when he off-roaded my Vette in the coal mines. As far as adjusting, well, someone else will need to answer :D -Matt-
Old Aug 25, 2002 | 08:11 AM
93TorchRedC4's Avatar
93TorchRedC4
Default Re: Marks on the windows (HighHopes85)
WHAT!!?? :crazy:
Old Aug 25, 2002 | 09:45 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Scratches on the outside of the window come from 3 main sources: 1) those little black felt pads being worn out; 2) the outside seal (the rubber thing at the top of the door and at the base of the window). The metal backbone at the base of the seal rusts and scratches the window; 3) and the third and least likely is grit stuck in the outside rubber seal.
To avoid any more scratching, replace both the seal and the felt pads.
Old Aug 25, 2002 | 05:58 PM
JP's C4's Avatar
JP's C4
Default Re: Marks on the windows (PTz-92-LT1)
But can you tell me how to get to the outher felt pads. It looks lik I have to get the complete window out? :confused:
Old Aug 26, 2002 | 06:09 AM
fast not first's Avatar
fast not first
Dacht niet dat je het glas hoeft te demonteren. Binnenbekleding verwijderen en glas in laagste positie laten zakken is volgens mij voldoende.
Old Aug 27, 2002 | 12:56 AM
RED84CF's Avatar
RED84CF
I have a bad scratch in my driver side window outside. It came from one of the rivets that hold the outside moulding to the door. Worked it self loose and before I noticed it scratched the window.
Old Aug 31, 2002 | 07:54 AM
JP's C4's Avatar
JP's C4
Thnx! U all!
To Marks on the windows
