96 shifter boot
Old Aug 25, 2002 | 09:10 AM
rayvette96's Avatar
rayvette96
5th Gear
Default 96 shifter boot
The shifter boot on my 96 coupe has unscrewed from the console. Any advice or directions on how to get it apart to screw it back in?
Old Aug 25, 2002 | 09:31 AM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: 96 shifter boot (rayvette96)
You've got mail.
Old Aug 25, 2002 | 09:34 AM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I replaced my shifter boot on my '94 not too long ago. You will need to remove the screws inside the console under the felt covering, and remoethe screw under the drink holder liner, in the front drink holder recess. I think the shifter plate will lift off enough at this point to re-tighten the screws holding it in place. If not you will need to remove the shift **** to completely remove the shifter plate. I also remember removing my console storage compartment lid, but not sure why. Anyhow, I hope this helps you get started.
:cheers:
To 96 shifter boot
