Here's my situation. I've noticed as of late that my shocks are starting to not feel as responsive. Upon inspection I noticed what looked like black cables coming off the top of the shocks. Checked my RPO codes and I do have FX3 option. Now this is what I find interesting. My car is a plain-jane base model and there are no controls in the cab for ride control. I don't understand. After doing research on here, my initial assumption is that the FX3 was only available on the ZR1 and as such, shouldn't there be some sort of control to adjust the shocks??? Finally, does anyone actual sell the electronic controlled shocks anymore? All the ones that I've found are non-electric.
The Selective Ride Control (FX3) system were available as a stand-alone option on both coupes and convertibles. The FX3 system was also part of the Z07 Performance Handling package. They weren't unique to the ZR1.
The SRC rotary switch would sit on the center console just between the power seat switches.. It could be that a previous owner removed the switch if the system had quit working.
IF the FX3 system is not working, you should see a "Service SRC" warning light on the DIC. If it's not illuminated, it could be that a prior owner removed the bulb to get rid of the message.
Also, in this thread, look at post #7. There is a detailed explanation on how to retrieve the SRC error codes. You will need to go thru this procedure to find out what is wrong.
Make sure that the SPID label on the console lid is a match to the car VIN. The VIN will be on the SPID. The controls missing might be more difficult to explain but you should be able to inspect for the harness connector without to much effort.
Replacement shocks? Possible but it would be very wise to confirm all of the actuators etc. are present and works as it should.
Base has little/nothing to do with the options.
You've not mentioned the year and that might be important so you can be helped as to the location of the controls.
WHAT YEAR?
Apologies, the year of car is 1994. As far as I can tell the little black actuators are on the shocks, all the wiring seems to be there too. Is there a way to test the light to see if it has been removed?
Seriously, I don't understand why people have to **** with this stuff. Just replace it for god's sake. You want electrical gremlins? cause this is how you get electrical gremlins.
I'm assuming this is what the Selector switch looks like?
And your car doesn't have this selector package. Correct?
You could start by checking for the connector in the console area. Do you have a FSM so that you can see where the balance of the components are located related to the RPO? You certainly need to start with an inventory of components. Lights mean "squat" without the components being present and "connected".
My 93 has the FX3 option also. Sometime before I bought the car the shocks were replaced by a set of KYB's. I looked into putting the FX3 shocks back on - they are about $300 each! May be a reason why some people **** with this stuff and don't replace.
Yeah, there is no selector there in the middle.
I'll pull the console apart and see if the wiring for the control is hiding down there somewhere. I do have the FSM for the car.
I believe, like most lights, the service ride control light (or lights, I would have to go look) should come on for a few seconds at startup (actually at key on).
Good Luck.
walt
Actually, a few years I paid close to 700 including shipping for all 4 brand new shocks. You can send them to Bilstein for rebuilding and revalving for less. And yes, the problem with people is they want a Vette but aren't willing to pay the price. IOW, I want it fast, reliable and cheap. Also, fries wouldn't be too bad.
I had the selector but the cheapskate PO pulled the bulb, the actuators and the shocks and gave me KYB. Fortunately, I got it cheap enough and tossed the motor and trans for what I have.
Well, I did verify that the SPID is the correct one for my car. It definitely came with the FX3 option. The shocks, actuators, wiring, and the "little black box" behind the driver seat is all there. If I get a chance today, I'm going to tear into the center console and look for the wiring.
I agree with aklim, I understand these cars are expensive to work on BUT that's the responsibility that comes with owning one. Good stuff ain't cheap, cheap stuff ain't good. That's why I drive a vette and not a camaro....
I recall a thread some months ago (maybe even last year) that Bilstein no longer has the parts to rebuild the rear FX3 shocks. They can still be revalved as long as the shocks are in working order. I do know that Bilsteing doesn't repaint the shocks after working on them. They don't have the decals anymore either.
My biggest concern is not the shocks; those I'll rebuild or replace. The main issue I'm trying to work out is the missing SRC switch, wiring, and service lamp. If the PO went to the trouble of removing all that, its scary to think what else they've screwed with and how hard/expensive its going to be restoring it.
I don't believe that. I'd remove the actuators and the bulb and maybe the switch. Rip off all the wiring? Why? Even my Bose wiring is intact. If you want to put the speakers and head unit back, you can. An owner that is too lazy and/or cheap to fix the system wouldn't bother to rip out all the wires
