early c4 front suspension angles
How I have it, the control arms are both pointing up, which doesn't seem anywhere near being correct to me but that's where it has the least amount of bump steer. My upper arm has almost 20* of angle.
The tie rod is at about 15* pointing up.
Trying to figure out what factory is at ride height for a better guideline. Or am I going about this wrong?
Alex
Thank you the pictures!
Do not set bump steer by changing the ride height.
Set the ride height to get the correct roll center.
If a street rod / custom car build attach the new frame section to the old frame in a higher or lower position to achieve correct stance.
Track car: When the roll center is correct the next thing is camber curve. A shorter upper a arm increases negative camber in bump (a loaded corner during a turn).
Next: Check & set toe steer. Slotted steering arms with heim joint rod ends in place of the stock outer rod ends are the answer for quick toe steer adjustments.
If a street vehicle toe steer may not be an issue.
If your road racing slot both steering arms & adjust both sides for 1/8 toe out in each direction during a turn. Suggest zero toe for straight ahead as a starting point.
Last: Remove spring & shocks.
Set the bump steer using spacers between the heim rod ends & the steering arms.
Good luck
BTW, the pic of the front suspension if accurate = a poor handling vehicle. The upper control arm is pointing down toward the outside of the vehicle. This causes the outside front tire when in a turn into positive camber = NFG.
Good luck
I can literally place the front subframe anywhere, Im trying to place it in the best spot and make everything else fit around that. Im to the point on the build where I cant go farther till I have the front suspension set in stone as to where its going to sit. I havnt checked the camber curve yet, but that does make sense as to the upper control arm. So no matter what you think the upper control arm should be at least level or angled down then move the subframe up till the roll center is correct? I am just using factory steering knuckes/tie rods/tie rod ends. Is there something else on the market or are you talking 100% custom made?
this is the build thread if your curious
http://ls1tech.com/forums/conversion...t56-build.html
thanks!!
Alex
suggest setting it up in the following manner.
Measurements are taken from one side of the stub the other side automatically follows suite.
Work with actual measurements, you need a sheet of drywall on a table or a clean floor & welders soap stone sharpened to a point & a long strait edge to extrapolate the A-arm pivot points.
Draw a 90* angle 24" high, 4-5' long.
The vertical line is your hub face. To simplify matters this line will also be the tire center line.
The horizontal line is ground level.
Mark the vertical line 13.5" up from the ground line this is the spindle center line.
If the coil over is installed remove it.
Since the new stub is basically hanging in space suggest fabbing a small A frame to bolt to the wheel studs. This will keep the spindle at the correct height while you jack the cross-member up-down.
As a starting point block the stub up to position the lower A arm level.
Add or remove upper control arm shims for zero camber @ the hub.
Straight edge on the hub face measure in to the ball joint center lines.
The ball joint center lines are 5/8" up/down depending on joint orientation from the metal stud retainer.
Record measurements.
Measure up from the floor to the upper & lower ball joint center lines, record measurements.
Transfer the ball joint center line measurements to your drawing.
Measure lower A arm length & inner pivot height -- transfer to the drawing.
Measure upper A arm length & inner pivot height -- transfer to the drawing.
NOTE the pic of the stub you are using shows anti dive built into the upper A arm mount.
Measure the front of the A arm pivot shaft to the ground, measure the rear of the A arm pivot shaft to the ground. Split the difference = upper A arm pivot height.
Measure hub face (vertical line) to center of front cross member, mark the ground line on the drawing,
Straight edge across lower BJ C/L & inner pivot CL draw a line 5-6' long.
Straight edge across upper BJ C/L & inner pivot C/L draw a line that intersects with the lower A arm line.
This is the instantaneous center.
Draw a line from the instantaneous center to the vertical hub center line @ ground level.
Call it the RC line.
At the cross-member center mark on the ground line measure up to the RC line
This measurement is your front roll center.
Raising the cross-member raises the roll center etc.
If the extrapolated control arm lines do not intersect you have a parallelogram suspension. It will not change with ride height = a poor handling vehicle.
Remedy: The upper A arm inner mount is positioned to high on the frame it needs to be lowered or:
Remove some anti dive by lowering the front mounting hole of the upper A arm shaft.
Use taller spindles or modify your spindles to position the ball joint higher. If you modify your spindles change the KPI to 10*.
Taller upper ball joints are available they are aftermarket designed for oval track racers.
Do not know if they are available for your application, check @ Howe racing.
Tall ball joints or spindles may interfere with the wheel dependent on spindle KPI, wheel diameter & amount of positive offset.
Edit: Looking at pix of your stub IMHO the easy way to modify the upper A arm inner pivot height to achieve an instantaneous center is to remove a portion of the 2x4(?) tube that supports the upper
A arm mount.
BTW if the upper A arm mount is welded to 11ga flat stock it will rip out during hard braking entering a high speed corner. Happened to the first tube stub that I built with 11 ga. Suggest attaching the upper A arm mount to 1/4" flat stock + add gussets.
Good luck.
A arm mount.
Good luck.
All the geometry is factory c4 as far as the mounting of the components goes. One of the fastest cars I've seen in autocross was a 700hp c4, stuck like glue somehow. Are you saying the stock geometry should be changed for the upper control arm? I have read that the c4 has positive camber gain right at first (and what you pointed out about the control arm proves that). Or is it a wait and see what it measures out to be?
Not seeing anything on the website, I'll have to give them a call to see if they have anything for it.
I believe it's 3/8" mount for the upper control arm. It's a pretty solid subframe! I couldn't imagine the suspension falling apart like that, talk about a scary situation!!
Thanks again!!
Alex
It occurred to me that stock upper control arms have the ball joint mount canted to match the frame anti dive.
I don't care how the stock Corvette suspension operates, factory builds are always compromised at some point for some reason. At this stage of your build you have the opportunity to modify what ever needs to be to get the front suspension geometry correct. Suspension modifications are very difficult after a car is built.
Draw out the suspension & lets see where everything is at. Doing so will determine what changes if any need to be made.
I wonder if it would be better to use a CTS or F-body cross member, which locates the engine much further forward relative to the wheels, than a vette based one? You dealing w/a car that was FWD which puts the wheels physically far back in the front end -note the distance from the rear of the wheel opening, to the front of the door; not much. Then you're using a vette based front end, which puts the front of the engine, behind the centerline of the front wheels...the engine gets stuffed back into the car, which is what you're dealing with. I'd think a different front end the situates the engine further forward, relative to the front axle centerline, would be easier to work with in that chassis.
Thanks!!
I'd keep it in mind. Our CTS-V has the engine sitting dead center on the axle line, has SLA suspension, and it handles pretty darn good. Best of luck. It's a cool project!
Thanks!
The roll center looks like it will be about 3" from the ground like this.
What's ideal front roll center?
Your front stub does not need modification + you now know what you have.
3" above ground roll center is good I happen to like that #. I am using a 3" front RC on the car I am building now. There is NO ideal front roll center number it is vehicle dependent. Rear roll center height, roll couple & center of gravity height all play a roll per vehicle. RC height is somewhat adjustable with a chassis height change but it will not make a notable difference. Chassis height changes = camber curve changes which have the biggest effect on corner speed.
I would install the stub LCA level the upper A arm will change to negative camber in bump. A shorter upper A arm = faster/more camber change for the track. I use plate spacers with shorter upper A arms
Good job!!! I'm happy for you.
So with my upper control arms.. spc adjustable. I removed all the factory c4 control arm spacers and bolted it directly to the subframe but adjusted to compensate exactly to what stock would be. I didn't know a shorter arm made for quicker camber change. Is there an ideal # of change per inch of movement? I have dug into that yet, never eve crossed my mind, I thought it was going to be what it was going to be.
Thanks!!
RC height is ok, above ground & centered under the car = good.
Check camber @ the static height of 13.5". Raise the spindle 1" take a camber reading to see where it goes. It should change to negative camber. For set up I like a 1* change in 1" of travel. Fine tune the camber setting at the track, read tire temps with a digital pyrometer.
You have an advantage using adjustable upper A arms. Shorten them up all the way, reset the camber with shims then take another reading raising the spindle 1". There should be an increase in negative camber.
Have the same digital level it is handy but I do not understand why it has a temperature function.
Theads like this=LOVE.
