Fuel pump power issues
Old Oct 24, 2015 | 07:42 PM
umrpunter's Avatar
umrpunter
Default Fuel pump power issues
I am working on my 1992 LT1 and have the following problem, hoping someone can get me over this hill.
There is power to the relay via the fuseable link on pin 87. It is hot all the time.
There is no power on 87A (ALDL pin G)
pin 30 is the route to fuel pump
pin 86 gets power for 2 seconds when I cycle the ignition switch then cuts off.
pin 85 is ground and tied to pin 86.
When I jump power to the pump it runs and puts out fuel (new walboro 255).
I am not getting power to the pump (or fuse) when I try to start this thing......I tested the relay by jumping pins 85/86 off the battery and it works fine. I also tried switching the relay next to it over to the FP relay spot......still having the issue. Is there something that should be keeping this relay open past those initial 2 seconds? Any suggestions on what to check next?
Old Oct 24, 2015 | 07:50 PM
antfarmer2's Avatar
antfarmer2
I believe the oil pressure takes over after the two seconds
Old Oct 24, 2015 | 11:55 PM
Cliff Harris's Avatar
Cliff Harris
The ECM turns on the fuel pump relay (and therefore the fuel pump) for 2 seconds when the ignition is first turned on to prime the fuel rails for starting. It then turns off the fuel pump relay so the fuel pump won't run continuously if the ignition is turned on but the engine is not started. The ECM will again turn on the fuel pump relay when it sees DRPs (Distributor Reference Pulses) from the ignition module. The ignition module generates DRPs whenever the engine is rotating, whether cranking or running.
The oil pressure switch is a BACKUP for the fuel pump relay. It is not needed and it is an Internet myth that it "saves" the engine if oil pressure is lost.
This is the fuel pump circuit diagram for my '86. I don't think much changed over the years:
The relay pin numbers/letters changed in several years, so watch for that. The connections are still valid. The diagram in your FSM probably doesn't look like this. I spent a lot of time modifying this diagram to make it accurate.
Old Oct 26, 2015 | 09:39 PM
umrpunter's Avatar
umrpunter
Man thank you so much for that. So get this, I do all the trouble shooting, getting deep into the passenger floor pan as fun as we all know that is. Well I pull the relay, jump it off the battery, and otherwise just fiddle with things. Darn thing works great now.........
I think the relay was just stuck, and needed a nice 650 CCA battery to kick it into gear.
So yea I ordered a new one of those, I am avoiding digging that out again as much as I can
To Fuel pump power issues
