You know its a bad day
Old Oct 25, 2015 | 02:35 PM
qws's Avatar
qws
Default You know its a bad day
when you finally get the heads on, torque'd down, rockers on and adjusted. Then bolt up the exhaust manifolds only to find out that the plugs are still in for the crossover tube on a LT1. Got one out... but the other no luck. The notch for the 1/4 ratchet is stripped and you can't get a pair of vise grips on it to remove it.... ugghh! Time for a beer and to remove one of the heads back off.
Then gonna have to buy another head gasket... bad day. But Shllt happens!
Old Oct 25, 2015 | 02:46 PM
John A. Marker's Avatar
John A. Marker
Just wondering since the gasket has not gone thru a heat cycle....could you spray it with Permatex copper spray?? Although it is almost the same cost as a new gasket.....a little less.
https://jet.com/product/detail/aa58a...FUhlfgodyroKWg
Old Oct 25, 2015 | 02:48 PM
383vett's Avatar
383vett
Can you JB Weld a 1/4" extension in the hole and attack it tomorrow?
Old Oct 25, 2015 | 02:57 PM
qws's Avatar
qws
Not sure about the copper spray gasket. I'd hate to bolt it all up and find in the long run it leaks.. may just sucked up the new gasket.
JB weld. cool idea. Not sure if I can get the extention to push in all the way but if I can I'll go for it. I've got a few exta 1/4 x 3/8 I could try that since its shorter and a 3/8 ratchet would certainly give me more leverage
Old Oct 25, 2015 | 05:46 PM
qws's Avatar
qws
A 1/4 ratchet will no longer go in, so I took a 3/8 nut and cleaned it with Acetone along with the end of the plug. Put it together with JB and I'll give it a good 24 hours to cure... then well see
Old Oct 25, 2015 | 07:32 PM
pologreen1's Avatar
pologreen1
Old Oct 26, 2015 | 01:35 PM
qws's Avatar
qws
LOL... that didn't work, took all of about half a second to pop the nut back off. And the JB was loaded up on it. Oh well, time to take the head off an redo
Old Oct 26, 2015 | 03:13 PM
383vett's Avatar
383vett
Bummer.
Old Oct 31, 2015 | 02:24 PM
qws's Avatar
qws
Default Unbelievable
All I can say is WOW... What did this guy do weld this plug in?.. holy cow
It may be time to just take it to a machinist to remove this for me. I can't take a chance and ruin those threads, especially since I don't even know the thread size.
Just bought these two... reman not new
Old Oct 31, 2015 | 03:52 PM
DanielRicany's Avatar
DanielRicany
Can you place a nut over it and weld the nut to it from the hole inside the nut? Then use a hex socket to remove...
Old Oct 31, 2015 | 03:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I completely Excellent advice and that is where I would go w/it, at this point.
OR weld a "pile" onto it, slide the nut onto/over the pile, then weld the nut to the pile...screw it right on out.
Old Oct 31, 2015 | 04:22 PM
qws's Avatar
qws
I'm sure that could work... but I don't weld
Maybe theres no better time to learn
Old Oct 31, 2015 | 05:05 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Do you have friend/bud who could help?
Wish we were closer!
Old Oct 31, 2015 | 05:20 PM
qws's Avatar
qws
I wish we were too
I do have one of those 110 volt Harbor Frieght Stick welders. I've always wanted to try it.
Old Oct 31, 2015 | 06:08 PM
antfarmer2's Avatar
antfarmer2
that does not look like the best place to learn better practice first.
Old Oct 31, 2015 | 07:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
...again. It's not THAT hard; your weld won't bond w/the aluminum b/c it's aluminum, but you don't want to make a mess, either. If you DO want to venture into this yourself, practice your welding on some pieces of flat stock, first.
Old Oct 31, 2015 | 11:35 PM
Dt86's Avatar
Dt86
Too bad you weren't closer, I'd lend you my mig. Your arc welder might be a little too hot for that. Use the lowest setting.
To You know its a bad day
Old Nov 1, 2015 | 12:07 AM
pologreen1's Avatar
pologreen1
I wish we were too
From what I have seen if it is the 80 amp one or whatever that one should work. Clean it up good and try it a few times, it's little money mostly time until you get good penetration.
Old Nov 1, 2015 | 12:15 AM
1985 Corvette's Avatar
1985 Corvette
Just did a quick image check of that LTx crossover tube. Yeah that does suck but you're like the rest of us, it doesn't stop us permanently. If you've got it off the car and having that much trouble still, I'd probably let a machinist give it a try too. I've only trusted those extractor bits on broken studs that are close in diameter to the bit.
Old Nov 1, 2015 | 09:52 AM
qws's Avatar
qws
Nope I would never practice on that head. However this would be a good time to get some flat stock and learn.
Meanwhile I've got a couple of ideas I can try today, and we will see what happens
