It will not start
Old Oct 25, 2015 | 04:27 PM
jseremba's Avatar
jseremba
Default It will not start
I own a 1989 Z51 with manual transmission. The car was not running when I bought it. In fact the engine was seized. But now it spins freely.
I have a new fuel pump in it and the two second start circuit is working. I have new ignition wires on the car and it does have spark. Is there a way for me to see if fuel is going into the cylinders?
Any ideas on the will not start is greatly appreciated.
Thank you
Joe
Old Oct 25, 2015 | 04:46 PM
antfarmer2's Avatar
antfarmer2
shoot some fluid in the intake and see if it starts or farts
Old Oct 25, 2015 | 04:54 PM
jseremba's Avatar
jseremba
Great idea. The car is asleep til next weekend. But, that is the first thing I will try.
Thank you
Old Oct 25, 2015 | 05:15 PM
antfarmer2's Avatar
antfarmer2
Thank you
I would talk to Jon at FIC good chance the injectors are gumed up.
Old Oct 25, 2015 | 06:42 PM
c4cruiser's Avatar
c4cruiser
Did you check the fuel pressure at the fuel rail? You may have something as simple as a dirty/clogged fuel filter. Also the fuel pressure regulator may be bad.
Old Oct 25, 2015 | 07:44 PM
pologreen1's Avatar
pologreen1
On your fuel rail is a Schroeder valve (like a tire stem) when the car is on your fuel pump should load the lines, remove the cap and depress it to see if fuel is in the lines. I agree, an easy way to start is fluid in the TB if there is spark. You said it was seized though so hopefully you have soaked and rinsed the motor with ATF etc several time and spun the motor over lots with no plugs to ensure no damage upon starting.
To It will not start
