transmission ?? flush out or not?????
Old Aug 26, 2002 | 02:14 AM
redcorvettedave's Avatar
redcorvettedave
Default transmission ?? flush out or not?????
94LT1 96,000 miles ,transmission had fluid completely changed out at 60,000 miles ????????? do I do this again or just replace filter an pan gaskets or what??????
Old Aug 26, 2002 | 07:28 PM
jefft84's Avatar
jefft84
Default Re: transmission ?? flush out or not????? (redcorvettedave)
30,000 mile intervals is great for flushing and every 15 a filter kit best insurance you can buy for your trans.
Old Aug 26, 2002 | 09:47 PM
badnewstravelsfast's Avatar
badnewstravelsfast
NO NO NO NO!!!! If it ain't broke don't fix it!!!! Just do a filter and fluid change....this comes directly from a friend who is a trans and driveline specialist. He has the fluid swap machine and turns anyone away with over 60,000 miles. He absolutely, flat out refuses to do mine. Just HIS $.02....not mine!!! :yesnod:
Old Aug 27, 2002 | 08:43 AM
jefft84's Avatar
jefft84
Default Re: transmission ?? flush out or not????? (badnewstravelsfast)
If a customer request a flush on a trans that hasnt been serviced for 60 k then sure turn them away. The equipment is designed for prevenetive maintenance to eliminate the buildup of varnish and clutch material in all the passages not cleaned with a filter change. If used for this purpose it does a great job of keeping out the bad stuff and extending trans life.
To transmission ?? flush out or not?????
