92 steering column reinstall
Old Oct 26, 2015 | 07:16 PM
reg_255's Avatar
reg_255
Default 92 steering column reinstall
Hey All,
Reinstalling my steering column.
There are a couple of things I'm not sure about.
Are these connector for the stock radio?
The radio was remove by the previous owner.
Is this black box a VATS by-pass?
What connects to the "L" shaped bracket with threaded studs at the firewall end of the column?
Thanks All for your continuous help and support.
Roy
Old Oct 26, 2015 | 08:43 PM
WVZR-1's Avatar
WVZR-1
1st snapshot? The ignition switch connectors are blue and black.
3rd snapshot? Is the car an M6 or an A4? The stud would be an anchor I believe for the park lock cable anchor behind the accelerator bracket. An M6 car doesn't have that cable so it would be just a "filler" for the hole.
2nd snapshot? If the wires near the box on the other side of the connector are wht/blk & ppl/wht then that's the only explanation.
Old Oct 26, 2015 | 09:40 PM
reg_255's Avatar
reg_255
Thanks for the reply.
1st shot, I didn't see a place for the blue and black connectors to plug in.
2nd shot wires are wht/blk & ppl/wht.
That means VATS bypass, so I don't need the cable from the ignition switch.
3rd shot, it's an automatic. there is a clip on the side of the column that holds the cable
Old Oct 26, 2015 | 10:01 PM
WVZR-1's Avatar
WVZR-1
That's the dimmer switch - roll the column over and you'll see the connector side of the ignition switch. Post a snapsot of the connector end if you doubt the function of them.
In this image #22 is the clamp and #23 is the bolt that with an automatic would be behind likely the accelerator pedal and through the flange. I was commenting in regards to the threads that are protruding through the flange, an M6 the bolt/screw holds nothing (just a filler). An A4 car the park lock cable should be anchored similarly to the image, the clamp, cable and bolt would be a finishing touch to the install. There'd be no reason for it to be there on the bench. Were you asking about something else? I didn't see an L-bracket that you described.
Name:  Park lock cable.png
Ignition connectors
Old Oct 27, 2015 | 06:25 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by reg_255
The "tag 5119" in this snapshot would have been attached (wrapped around) the wiper switch harness indicating that the switch pig-tail you mentioned not being able to find certainly should be there. The plastic filler in that snapshot is what was likely covering that pig-tail and after removal of the filler you certainly shouldn't have had any problem finding the connector. Did you solve that issue yet?
Old Oct 27, 2015 | 10:36 PM
reg_255's Avatar
reg_255
It's raining in North Carolina and tomorrow looks to be no better.
So I don't think I'll get back to it until the weekend.
Regards,
Roy
Old Oct 30, 2015 | 10:48 PM
reg_255's Avatar
reg_255
Hey All,
So I'm pretty sure I figured out where all the connectors go.
I'm wondering what this black box is?
Its wired into ignition wire.
Is it a remote start? If it is, how would I get a fob for it?
Thanks,
Roy
Old Oct 31, 2015 | 05:33 AM
WVZR-1's Avatar
WVZR-1
That's certainly a possibility. GOOGLE IMAGES could be your friend, just keep poking around until you find something similar. Use the instructions of what you find to compare the pin-outs to what you've got to maybe ID the branding. Is there anything on the label? What's molded into the box?
If you mentioned the connector pin letters and wire colors that the component is wired to maybe it's easier to actually ID the component for you.
A remote start would explain maybe the presence of the VATS by-pass component.
It could maybe also only be a remote entry module also.
To 92 steering column reinstall
