shift points ?
Old Oct 27, 2015 | 10:46 AM
jlfx car audio's Avatar
jlfx car audio
Default shift points ?
Based on this dyno sheet where would you shift for acceleration ?
4+3 manual .
Old Oct 27, 2015 | 11:25 AM
DanielRicany's Avatar
DanielRicany
Old Oct 27, 2015 | 11:39 AM
jlfx car audio
My 6al is set to 6600 which is where it falls on its face (tho the graph shows its 6200(blue line) but guess this is due to the dyno operator not hitting the stop run button as it cuts instead of after (this mustang dyno didn't use a tac wire )...
Old Oct 27, 2015 | 11:41 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Based on THAT graph, I'd shift at 6200. By 6300, power has plummeted by at least 50hp depending on the run. I don't think that graph is useful for calc'ing ideal shift point as the run was cut off too soon.
Old Oct 27, 2015 | 11:54 AM
jlfx car audio
Yea the black line the rev limiter was set to 6400 and since it was still flat i raised it by 200 rpm and still reved strong till cut
Old Oct 27, 2015 | 12:16 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If it were my car and I wanted to have clarity on the curve and shift points, I'd go back and test again.
Old Oct 27, 2015 | 12:42 PM
jlfx car audio
I don't disagree ... But I will take it to another dyno to have it tested for scca racing (this place isn't on their list yet )
Old Oct 27, 2015 | 03:37 PM
DGXR's Avatar
DGXR
HP and TQ drop dramatically after that, and RPM after shifting would still be in the fattest part of the torque curve with HP building strongly.
Old Oct 28, 2015 | 10:18 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by DGXR
6000
As already mentioned above, I don't think that you can make a concise determination from that graph; dyno operator ended the run @~6000 RPM...so that "Drop dramatically" is a result of the throttle closing...not a natural taper of the tq curve. His ideal shift point would be higher than 6000, but hard to tell and impossible to calculate w/o the proper data there.
Old Oct 29, 2015 | 08:00 PM
jlfx car audio
Where the graph begins to decline is where the 6al is cutting spark. So my thinking is the dyno operator didn't cut the dyno off till a sec or 2 later . guessing since he had the graph in the system set from 2500-6500 it based the run on the time between the start and stop functions . thus making it look as if my power falls off quickly based on acceleration cause once the ignition is cut it no longer increases rpm ... Wish I felt comefortable to extend the limiter to 7000 but without a a/f gauge on the dyno I didn't feel comfortable doing that
Old Oct 30, 2015 | 10:35 AM
383vett's Avatar
383vett
Why would anyone have a dyno without an a/f gauge?
Old Oct 30, 2015 | 10:46 AM
jlfx car audio
It had one but he couldn't get it to work.... They mostly do diesel tuning ... But yea I wasn't happy about that ... I have a gauge installed but always like to confirm that's it right with a proven one ....
Old Oct 30, 2015 | 09:34 PM
l98tpi's Avatar
l98tpi
Max G’s
I would shift 5250 to 5500 but I am not a drag racer
Old Nov 3, 2015 | 08:47 AM
aboatguy's Avatar
aboatguy
Go to a dynoshop that will do pulls while logging the A/F you may be surprised at the result.
Mike
Old Nov 3, 2015 | 09:03 AM
jlfx car audio
Yea it will happen before next season (mar)
Old Nov 3, 2015 | 03:08 PM
Kevova's Avatar
Kevova
Between 5250 and 6000 depending on competition and type of event. To stretch over 6k, because it would not happen just once, I would have to know engine will take it. A broken valve spring for example would make for a bad day.
To shift points ?
