Just had the ECM replaced in my 1985 Corvette and now my oil pressure seems to be running really high. It drops to around 43psi at idle, but when running at a steady speed of around 35-40, it jumps up and down between 55psi and over 80psi. If I am idling it and punch the gas, it jumps to over 80psi. Any thoughts?
just pull your oil pressure sender and put it there or put a t in so you can have both.
Thank you!! What does the gauge look like? We have been told different things and do not want to get the wrong gauge. I have spent so much money on this car in the last few months, I certainly do not want to waste money buying the wrong type of gauge.
I would confirm the connection and probably just spend the money for a new sender for the gauge aspect of the cluster. There are procedures for checking the accuracy and function of the dash gauge/cluster and you could check the sender itself for inconsistency that would explain your what you're seeing.
I'd think the replacing of the sender less expensive than the ADDING of another and certainly less complicated.
Use the orig GM # as a reference at your local auto parts store for a purchase. GM # 14078954.
Yours should have a single spade connector and be somewhat bell-shaped unless it's been changed. The sender uses I believe resistance of 3 to 90 Ohm. If you've a DVM you could check the sender at idle and appropriate greater RPMs and see what the sender is actually producing before removing to replace.
1st though - the ECM has nothing to do with the oil pressure gauge at the cluster - NOTHING - If the car runs the ECM I guess you could say is doing the greater part of it's job.
For reference purposes, this is what the oil pressure switch and sender look like. Located behind the distributor. The oil pressure sender is the large diameter part with the single wire attached:
Reason: Corrected grammatical error.
I with Cliff on this. Most likely the sender is going flaky. But I might also ,on an a chance, replace the oil filter. It's unusual, but a blocked filter can cause high pressure (via the bypass). Filter change is very cheap and easy. Although not as cheap as checking the sender with a Digital Volt Meter
Was it working before ecm switch
Why did you switch ecm
Did you clean EMC connectors with electrical cleaner if they were exposed they could be dirty.
Who changed ecm
Good luck
