Rear Diff. Oil Change
Old Aug 26, 2002 | 08:37 AM
Polar LT4's Avatar
Polar LT4
Default Rear Diff. Oil Change
I'm going to change the oil on my Dana44. Should I use one bottle of posi additive or two? Also, what oil should I use (weight wise), and should I stick w/ the dino oil or go synthetic. How much oil do I need?
I'll be using a plunger/suction type pump & will do it when the rear end is hot (try to get the sludge suspended). Anybody have words of wisdom?
Old Aug 26, 2002 | 10:29 AM
Rob90's Avatar
Rob90
Default Re: Rear Diff. Oil Change (Polar LT4)
I would go synthetic. Mobil 1 Amsoil and Redline all make good 75W-90. I believe all 3 of these have the additive already in them. You might get some chatter in the posi without some extra additive. I know if you go with Red Line you will have to use there Posi additive due to GM not mixing with there base stock. Amsoil I am not shure and Mobil 1 will mix with GM additive. I used Mobil 1 without any extra additive and have no increase in rear end noise.
Old Aug 26, 2002 | 10:35 AM
silver & red CE's Avatar
silver & red CE
I use Mobil 1 with one bottle of additive. Mobil 1 doesn't have the additive, I've replaced the diff fluid in my Impala and found out the hard way it needs two bottles ;)
Eric
Old Aug 26, 2002 | 10:41 AM
Rob90's Avatar
Rob90
Default Re: Rear Diff. Oil Change (silver & red CE)
So did I scew up by not using additive. Here is there data sheet
http://dallnd6.dal.mobil.com/GIS/Mob...f?OpenDocument
I just saw aht it was good for limited slips and thought I was OK. Glad I have some GM additive on the shelf
[Modified by Rob90, 8:51 AM 8/26/2002]
Old Aug 26, 2002 | 04:19 PM
Rick86's Avatar
Rick86
Default Re: Rear Diff. Oil Change (Rob90)
I believe Royal Purple doesn't require limited slip additive.
Old Aug 26, 2002 | 09:36 PM
Knight Ryder's Avatar
Knight Ryder
St. Jude Donor '05-'06-'07-'08
Default Re: Rear Diff. Oil Change (Rick86)
Their "Max-Gear" oil does say that limited slip additive is already mixed in.
I just put some of this in my ZF-6 and DAYUM!!! This thing shifts like a completely different transmission! Definite improvement! :yesnod: I'll be using this in the differential next...
Old Aug 27, 2002 | 12:52 PM
Polar LT4's Avatar
Polar LT4
Default Re: Rear Diff. Oil Change (Knight Ryder)
Is the Royal Purple OK to use in a ZF tranny?
To Rear Diff. Oil Change
