Looking for some help
once in a while it will start up and idle at about 750 for a few minutes, rev and drive good, but then the idle will kick up to 1400 and act up again. I haven't found any vacuum leaks, doesn't mean there aren't any. I've replaced most of the vacuum tubing and the EGR valve. next step was going to be the EGR solenoid but I cant seem to find any available.
Any ideas you could throw at me would be greatly appreciated. had the car for about a year and cant drive it. getting frustrated.
thanks in advance'
Chris
sorry iac idle air control
David
If it runs bad when driving down the road, I would suspect egr valve or timing is off. Your distributor could be turning due to the lock down bolt being loose.
Happy Holidays and I will keep you posted, getting to cold to do much to it plus the snow is coming soon I am sure.
Chris
Chris
Good luck
Tools & Equipment
You will need the following tools and equipment:
1. A set of Torx wrenches. You can buy a complete set in a nice, genuine plastic pouch at Sears.
2. A good digital voltmeter that will read voltages less than 1 volt.
3. A paper clip.
4. A small screwdriver.
Procedure
There are two electrical components on the TB that you will be working with: The TPS and the Idle Air Control Valve (IAC). Make sure that the connectors for these two components are easily accessible and that you can easily disconnect the IAC.
You will also be playing with the diagnostic connector under the dash. Remove the cover (if it’s still in place). Bend your paper clip into a "U" shape. You will be playing with the two top right hand terminals ("A" and "B") in the connector.
First step is to set the minimum idle speed. If nobody has messed with this on your car before, the set screw will be covered by a pressed-in plug. It’s located on the driver’s side of the TB. Remove this plug if it’s there.
With the IAC connected and the ignition "OFF," stick the paper clip into the diagnostic connector from "A" to "B." This grounds the diagnostic lead.
Turn the ignition to the "ON" position without starting the engine. Wait 30 seconds.
Now, with the ignition still in the "ON" position, disconnect the IAC connector at the IAC.
Remove the paper clip from the diagnostic connector.
Start the engine and allow it to reach normal operating temperature. The idle speed will probably be really low, and you may have to coax the engine a bit with the gas pedal to keep it running for a while.
If your car is an automatic, set the parking brake and put the transmission in "DRIVE." If your car is a manual, leave it in neutral.
Adjust the idle speed screw to obtain 400 rpm in drive or 450 in neutral.
Shut off the engine and re-connect the IAC.
That’s it for idle speed. Now on to the TPS.
There are 3 wires stacked vertically on the TPS. You will need to be able to measure the voltage between the two top wires. You can either buy a special harness connector that breaks these wires out (from Mid America), or gently pierce the insulation of the wires with the pointy prongs on your volt meter. You can also stick a paper clip into each of the two top locations of the connector and clamp onto the paper clips to measure the voltage. Whatever is easiest for you.
Loosen the TPS Torx (phillips)adjustment screws.
Set your volt meter to a low scale DC volt setting that will accurately read less than 1 volt.
Measure the voltage between the two top TPS wires.
Adjust the TPS by rotating its position until you get a reading of .54 volts.
Tighten the Torx screws and recheck the voltage. Re-adjust if necessary to make sure voltage is right at .54.
Turn the ignition "OFF."
You are now in perfect adjustment on idle speed and TPS output. Start the engine. It may take a few seconds for the car to "catch on" to its new settings.
Chris
Thanks again everyone for the help.
Chris
David
Thanks much Cheerless for the info and this thread, it saved a lot of headache and money. My only problem now is it seems to sputter/miss on acceleration, but only before it warms up, then it seems to run good. Oh well, one problem solved, and one to go. Thanks again, Cheerless.David
big range on them $10 to $60
make sure the connections are good.
