L98 Idles rough, dies when accelerate
Old Nov 3, 2015 | 11:24 AM
87L98Vette's Avatar
87L98Vette
Default L98 Idles rough, dies when accelerate
hello! new to the forum! just got an 87 Vette, with the L98. trying to figure out this problem, the engine has been messed with quite a bit. it has extra plugs laying around, but all the important stuff to make it run seem to be plugged in, it turns on, fires up. and it idles, a little rough, and doesnt allow to accelerate, if u try to accelerate it does the opposite and bogs down and eventually dies. the previous owner did say, (which i dont really trust anymore) said the car drove and ran fine before he swapped the the distributor. so i thought it was just the timing that was off, but i checked it and tuned the timing a little and it still does the same thing. checked spark, all 8 plugs spark, although they are black from carbon, when i did check all the plugs, i did notice #3 plug was brand new shiny, which only led me to suspect that the injector isnt working. i have been reading a lot as well, many people say its vacuum, and other say its gas. im pretty sure its gas, or maybe a combination of both, the other day i sprayed carb cleaner into the intake and accelerated and it was the first time i ever heard her accelerate. any ideas what it may be guys?
Old Nov 3, 2015 | 11:31 AM
antfarmer2's Avatar
antfarmer2
crap shoot here but would see what the fuel pressure is and injectors are working could. evan be a pluged cat or many other things can you take a pic of things not hooked up?
Old Nov 3, 2015 | 11:36 AM
87L98Vette's Avatar
87L98Vette
Oh yeah I forgot to mention, yeah the fuel pressure is between 40-38, and it has no cats.
Old Nov 3, 2015 | 11:51 AM
antfarmer2's Avatar
antfarmer2
ohm out your injectors hot and cold yours are batch fire so one bad one can kill them all.
call Jon at fic just look to the adds to the right
Old Nov 3, 2015 | 12:37 PM
87L98Vette's Avatar
87L98Vette
what is considered hot?
Old Nov 3, 2015 | 12:40 PM
antfarmer2's Avatar
antfarmer2
after you run the engine up to temp.
Old Nov 3, 2015 | 12:48 PM
87L98Vette's Avatar
87L98Vette
i knows it was a dumb question haha just had to make sure haha
Old Nov 3, 2015 | 12:49 PM
87L98Vette's Avatar
87L98Vette
its suppoose to be between 11-17 ohms right?
anything below is bad?
Old Nov 3, 2015 | 01:16 PM
antfarmer2's Avatar
antfarmer2
sounds about right. I think 16 is the sweet spot.
Old Nov 3, 2015 | 01:20 PM
87L98Vette's Avatar
87L98Vette
awesome! i just bought a Noid Lite kit, ill be checking the injector pulse as well as injector resistance. if anyone can think of any other ideas let me know!
Old Nov 3, 2015 | 01:24 PM
aklim's Avatar
aklim
IIRC they are Multecs. Call FIC to verify. If they are, I'd just toss them and get reman units. Ohming injectors are a poor man's way of trying to get some assurance that the injectors are working. You can't tell if they are clogged and you ASSUME they are working fine because the ohm numbers are good. To me, that test is so misleading, it is worse than nothing.
Old Nov 3, 2015 | 01:29 PM
aklim's Avatar
aklim
So it runs poorly. No worries. Get it running and see if you can get good clean spark. Take a plug off and put a fresh plug in the wire, ground the thread and see if you get a solid blue flame and pulse regular pulses. Do it for all the others. Also, check you distributor and see if the cap is good. Spray a fine mist around the wires in a dark garage and see if you get a light show.
Take the fuel pressure regulator hose off and see if the fuel pressure goes up and to what. If you can, do a WOT run and see if there is a lot of drop off in fuel pressure.
Old Nov 3, 2015 | 01:30 PM
aklim's Avatar
aklim
Also get yourself a scanner. Not a code reader, that can be had at Office Depot at the paperclip section. Get a real OBD 1 scanner.
Old Nov 3, 2015 | 04:02 PM
Dt86's Avatar
Dt86
Are you getting a SES light? Any stored codes? A scanner and FSM will be the best tools you can buy for your car. Otherwise you can end up throwing parts at it and fixing nothing.
Old Nov 3, 2015 | 06:14 PM
87L98Vette's Avatar
87L98Vette
I got my injector readings,
The noid light confirms all the plugs are working properly, now the ohm ratings on them aren't very good. These are it, numbered by cylinder, also "c" just stood for cold. I don't have hot readings yet.
Injectors
1: 8.3 c 2: 8.2c
3: 7.2 c 4: 7.0c
5: 16.6c 6: 11.7c
7: 16.3c 8: 16.6c
87L98Vette's Avatar
87L98Vette
No SES Light.
And checked for codes and there are none.
Old Nov 3, 2015 | 06:22 PM
antfarmer2's Avatar
antfarmer2
Injectors
1: 8.3 c 2: 8.2c
3: 7.2 c 4: 7.0c
5: 16.6c 6: 11.7c
7: 16.3c 8: 16.6c
time to call Jon. would not evan bother with hot.
To L98 Idles rough, dies when accelerate
Old Nov 3, 2015 | 06:34 PM
87L98Vette's Avatar
87L98Vette
U think it's safe to say that's what's causing the issue?
Old Nov 3, 2015 | 06:38 PM
antfarmer2's Avatar
antfarmer2
don't know the history 0f the car but I think it is safe to say you need new injectors. I would flush the system and change the fuel filter at the same time.
Old Nov 4, 2015 | 11:09 AM
87L98Vette's Avatar
87L98Vette
well guys! i spoke to Jon! the man! haha i ordered some injectors, cant wait to get them and slap them on and hear my baby purr and take her for a proper spin!
