fuel pump
Old Aug 26, 2002 | 04:39 PM
insanegt1's Avatar
insanegt1
Default fuel pump
On the fuel punp comeing out of the top there are two lines on the left that go around the fuel neck and and go to the right and one on the right going to the left. What one is the pressure return and the feed. Need to clamp them off to find if the diaphram on the rail is holding or the back pressure valve on the pump is bad.
Old Aug 26, 2002 | 04:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: fuel pump (insanegt1)
My '88 Vette GM Shop Manual shows the one closest to the rear as the fuel return hose and the front one as the fuel feed hose.
The single line that goes to the left is the vapor hose.
Old Aug 26, 2002 | 04:49 PM
scorp508's Avatar
scorp508
That top/right one is always the one spraying fuel at me, so I would definitely guess that is the feed line. :D
To fuel pump
