Solid axle C4?
Old Aug 26, 2002 | 05:58 PM
WEDGE's Avatar
WEDGE
Default Solid axle C4?
Just wondering if anybody has any pics or technical info on putting a solid axle into an 84 vette. A friend of mine is turning his into a 9 1/2 streeter and wants to to a solid axle/tubbed setup. If anybody can help I will relay the info to him.
Thanks.
Wedge. :) :)
Old Aug 26, 2002 | 06:53 PM
1991Z07's Avatar
1991Z07
Default Re: Solid axle C4? (WEDGE)
I've seen some, but not from underneath and how they did it.
Needless to say it is a daunting task. The C-channel beam that connects the trans to the rear differential is all stationary. Going to a solid-axle means all that stuff back there is moving vertically up & down. How you get this to work is going to be a trick.
There is an 8 or 9-second ZR1 out there who did this. You might go the the ZR1 net to find out who he is and how to contact him.
I thought about this last year. I suppose you can make a solid rear-end that bolts up like the IRS. Funny cars and dragsters have no rear suspension movement and rely on the rear tires to soften the launch, etc.
On the other hand, I do know of one particular '68 BB N/A (no NOS) 550++ cu/in (he won't say EXACTLY how many cubes it really is) coupe that runs low 9's regularly. He does it with a full IRS, and changes the universals every 10 runs.
What a sight to see...1000 HP (yes...I've seen the dyno sheets) hazing the 14" Goodyear Drag slicks all the way through the lights. I've got some good video of it from on top of the timing tower at Gateway (St. Louis)...
[Modified by Joe90, 5:19 PM 8/26/2002]
Old Aug 26, 2002 | 11:47 PM
HWoods's Avatar
HWoods
Default Re: Solid axle C4? (Joe90)
I don't think it would be an extreme major task. I have been thinking about it for my 86. You basically have a 4 link suspension but must allow for the C channel to properly align the rear end. I have seen some pics here on the forum and there are a couple of the members here running them
Old Aug 27, 2002 | 12:14 AM
The Green Rocket's Avatar
The Green Rocket
Try to contact forum member "Wheelsup", I do believe he runs a 12 bolt differential on his C4. If I remember correctly, it was not all that hard a task - counting on a person being mechanically/fabricator inclined.
Thomas
Old Aug 27, 2002 | 02:55 AM
VetteRacer282's Avatar
VetteRacer282
Go ask in the Drag Racing section of the site if you havent already, I know atleast 1 person has done it.
G'luck
Matt
To Solid axle C4?
