More coolant problems... Green slime. LC light.
Old Aug 26, 2002 | 06:10 PM
Kale's Avatar
Kale
Default More coolant problems... Green slime. LC light.
Sometimes it seems as if the car doesn't take the water from the overflow tank - in fact, it overflows, gives me a LOW COOLANT light, and the car gets over 240. The fans do come on
I can shut the thing down, wait a few minutes, and go.. And it works just fine. Once in a while, it will run low on coolant and I have to add more.
The only sign of a leak i can find, is towards the lower radiator hose side, on that beam under the front of the engine may be a few drops of water. The water pump is dry as a bone, and I already changed the hose out.
Also, the coolant seems to have a slime in it... Like algae growing on the dipstick. I doubt it's oil - it's pretty "saturated" by the water.
Any insight? Thanks.
Old Aug 26, 2002 | 06:29 PM
bogus's Avatar
bogus
Default Re: More coolant problems... Green slime. LC light. (Kale)
you need to do a complete back flush.
the slime is 15+ years of built up scum... it needs to come out...
I think Zerex makes one of the nice flushes....
Also, check for a shop that services using BG products.
BG uses a machine that will pump cleaner through backwards and filter it out. cleans pretty good, from what I have heard.
Old Aug 26, 2002 | 06:34 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
If you have the aux oil cooler, check the aluminum tube from the heater hose to the oil cooler. See: http://forums.corvetteforum.com/zerothread?id=373064
You coolant will boilover around 125* or so if the system does not hold pressure. The pressure cap gives you all the boil-over protection. If you have a leak (no pressure) and exceed around 125*, it turns to steam and has no cooling effect any longer until it cools back into water / coolant.
I also have found that the pressure cap seems to only last about 2 years, so now change with each coolant flush.
The slime may just be the left-overs from the sealing tablets. I don't use them anymore. Could also be really old coolant, but doubt it. Mine has been nice and clean since I stopped putting the tablets in.
Pete
Old Aug 26, 2002 | 06:37 PM
Kale's Avatar
Kale
Default Re: More coolant problems... Green slime. LC light. (bogus)
Can I flush it myself?
isnt the oil cooler on the drivers side, rear?
I think Iv'e replaced that before
Old Aug 26, 2002 | 06:51 PM
PeteL's Avatar
PeteL
Yes.
It attaches to the heater hose near the fuel lines and water pump, somewhat passenger side. An aluminum tube brings the coolant from the heater hose, around the oil pan to the other side of the engine.
Old Aug 26, 2002 | 07:01 PM
Kale's Avatar
Kale
Default Re: More coolant problems... Green slime. LC light. (PeteL)
Ah yeah, I replaced the parts there quite recently. Took me quite a while to find out how that coolant got on my brake booster.. till i looked under the car.
Old Aug 26, 2002 | 07:14 PM
PeteL's Avatar
PeteL
Hmmm, aluminum tube is new?
I guess I would check the other connections on the water pump for leaking, and intake manifold.
If you have an Autozone nearby (or a buddy with one) you could use a pressure tester. Pump the cooling system up to 15 #s and try to find the leak. You could also add a UV dye to the coolant and drive for a while and come back with the light and see what you can see.
Old Aug 26, 2002 | 07:25 PM
fixvet's Avatar
fixvet
Sounds like a classic bad radiator cap. Get a super duty cap.
Old Aug 26, 2002 | 07:31 PM
Kale's Avatar
Kale
Default Re: More coolant problems... Green slime. LC light. (fixvet)
That damn thing is new too.. I bet it's still under warranty.
Old Aug 27, 2002 | 12:24 AM
Kale's Avatar
Kale
Put the thing up to the system, pumped it to 16psi.
Couldnt find any leaks.
Hooked it to the cap, and the cap would only hold 14psi
put on a new 16psi cap. The old was 17.
Still get low coolant light a lot, but no weird heat readings. Will burp the system tomorrow. Thanks.
[Modified by Kale, 8:25 PM 8/26/2002]
Old Aug 27, 2002 | 12:40 AM
TIMSPEED's Avatar
TIMSPEED
I was getting the low coolant light alot. I just added more coolant. First I filled my overflow tank like almost full. Then I opened the radiator and filled it, then turned the car on with the heater on, let it run to 180º(thermostat opens at 160º) And filled it with as much as I could get in it, took it to 2500rpm, filling it. Capped it and let the RPM's fall. Haven't had any trouble since!
To More coolant problems... Green slime. LC light.
