1990 HVAC Problem - Dashes on display
Old Nov 9, 2015 | 02:37 PM
Agent13's Avatar
Agent13
Default 1990 HVAC Problem - Dashes on display
All,
I am having an issue with my C4's HVAC. The blower fan is permanently on. I have no response from the head when I try to use it normally, and when I tried pulling up the codes none were stored. Has anyone had this issue before?
Thanks in advance!
Old Nov 9, 2015 | 06:12 PM
Agent13's Avatar
Agent13
Pulled the programmer from under the dash and replaced the capacitors. No change.
Old Nov 9, 2015 | 10:30 PM
Agent13's Avatar
Agent13
Finally was able to make the programmer function. Now I have a Code 6 Inside Air Temperature Sensor short. Does anyone know where this is located on a '90?
Old Nov 10, 2015 | 01:32 PM
kenpeindl's Avatar
kenpeindl
Have you tried this fix? I had a similar problem with my auto climate control. Take a look at this video. It wasn't hard to do and it did fixed my problem.
http://www.vettetube.com/climate-con...r-c4-corvette/
Old Nov 11, 2015 | 11:07 PM
Agent13's Avatar
Agent13
The dashes reappeared on the control head. I am able to make it function somewhat by disconnecting and reconnecting the programmer, however, the codes 2, 4, 6, 8, and 10 appear. Looks like I will be trying another programmer.
Old Nov 15, 2015 | 01:17 AM
Agent13's Avatar
Agent13
New (used) programmer arrived today. Installed the new capacitors I had put in the old programmer and connected it to the car. Everything now works as it should.
Old Nov 15, 2015 | 06:42 AM
hcbph's Avatar
hcbph
Good to hear you got it fixed.
To 1990 HVAC Problem - Dashes on display
