Re: Doesn't Spray When Bottle is Below 5 Lbs (HOWSER)
Do you have your bottle sitting where the pickup tube is at the bottom? Mine usually starts showing extremely low pressure when the juice quits hitting, indicating I am running low on laughing gas.
Re: Doesn't Spray When Bottle is Below 5 Lbs (ForceInjection)
If you get a bottle warmer you can get more pressure out of it.
Yes, while this will help, it will not allow use of all your nitrous. As 1QUIKLT1 said, make sure everything is situated correcly, and make sure you do not have a bottle that someone removed the siphon tube from.
Re: Doesn't Spray When Bottle is Below 5 Lbs (95AquaC4)
Yes, I have the bottle sitting correctly. I guess when it get lower it must not want to spray as well as when it's full. A bigger bottle is in need. There goes the idea of hiding it under the cargo tarp! :D
HOWSER...
I have my 15lb bottle and my system in the back area. I mounted the bottle on a piece of wood and it sits behind the driver seat and I have a 12"Bandpass box with amps mounted on the sides of it behind the passenger seat.
