nitrous spark plug.....
Old Nov 15, 2015 | 12:19 PM
ricky's c4's Avatar
ricky's c4
Default nitrous spark plug.....
what is a good plug to use with a 125 shot of nitrous....everything else is completely stock.....
Old Nov 15, 2015 | 02:04 PM
DanielRicany's Avatar
DanielRicany
2 steps colder than stock, non projected tip.
Old Nov 15, 2015 | 09:33 PM
ANTI VENOM's Avatar
ANTI VENOM
Good advice Daniel. I ran projected tips with nitrous long before I knew there were non-projected tips and everything worked out for me. I also had other safeties in my car. A Nitrous mastermind was the center of it. It retarded the timing, shut off the nitrous before the rev limiter, and was progressive. I am not telling you to run this plug, but many have been happy with the NGK BR6EF. I believe that is one step colder. Many have also run the TR6 and been successful. I personally would look at the BR6EF or BR7EF. I like NGK. The choice is ultimately yours. With a safe tune, it probably won't matter what plug you run. (within reason)
Good luck, have fun, and educate yourself.
Old Nov 15, 2015 | 11:24 PM
DanielRicany
Originally Posted by ANTI VENOM
Good advise Daniel. I ran projected tips with nitrous long before I knew there were non-projected tips and everything worked out for me. I also had other safeties in my car. A Nitrous mastermind was the center of it. It retarded the timing, shut off the nitrous before the rev limiter, and was progressive. I am not telling you to run this plug, but many have been happy with the NGK BR6EF. I believe that is one step colder. Many have also run the TR6 and been successful. I personally would look at the BR6EF or BR7EF. I like NGK. The choice is ultimately yours. With a safe tune, it probably won't matter what plug you run. (within reason)
My NOS kit says that for a stock engine you can leave the plugs stock. I'd still change them to be safe.
Old Nov 16, 2015 | 11:37 AM
ricky's c4's Avatar
ricky's c4
I bought the tr6.....I still have the platinum plugs in it....got to get them out all the stories I heard with the pucks coming off.....
To nitrous spark plug.....
