Thread size for the 4+3 overdrive pan?
Old Aug 27, 2002 | 09:08 AM
LD85's Avatar
LD85
Default Thread size for the 4+3 overdrive pan?
Does any one know the meteric thread size for the OD pan? Two threaded holes are stripped and I want to get a helicoil kit for the two holes. I am debating on putting English threads back in. I think the precious owner or service man has stripped them beacsue when I went to change the fluid the bolts were bascailly held in with permetex.
TIA
:seeya
Old Aug 27, 2002 | 09:54 AM
scorp508's Avatar
scorp508
Ouch that stinks! Remind me later today to look in my service manual when I get home because I will probably forget otherwise. :)
Old Aug 27, 2002 | 10:40 AM
LD85's Avatar
LD85
Default Re: Thread size for the 4+3 overdrive pan? (ld85)
Does M-6 sound right?
Old Aug 27, 2002 | 10:41 AM
scorp508's Avatar
scorp508
Nope. M-10 sounds more like it. I'm about 99% positive it is a 10mm head, but I do not know the tread pitch. (I would assume 1/mm)
Old Aug 27, 2002 | 10:59 AM
LD85's Avatar
LD85
Yes the hex head is 10-MM across the flats.
I have OD pan bolt in my hand and the thread OD measures just under 6mm.
I remember putting in a 1/4-28 bolt to try to tighten the pan up temporarily so I am pretty sure it is the 6-mm.
[Modified by ld85, 10:00 AM 8/27/2002]
To Thread size for the 4+3 overdrive pan?
