DEX-COOL ANTIFREEZE QUESTION
I put this stuff in after my heater core replacement and was wondering if I should flush it out again. I certainly don't want to replace the core again in a couple of years. Thanks for the thoughts............
Guys on classic car boards who changed over to DexCool (for reasons unknown to mankind), had problems with bacterial growth during down times. Seems the little buggers like the organic additives. Many reported finding pressure in the system after a couple months storage.
GM also does not recommend using DexCool on pre 94 cars. Speculation involves seal technology changes, location of the overflow tank, block hot spots and so forth.
If you run Dexcool make sure you test pH every couple of months and if it goes below 7.2 to 7.0 flush it (this informatin I got direct from a Texaco engineer). Never let the level get low. Run the overflow level at "full hot" when cold. Use a positive spring pressure Stant pressure cap to insure the vacuum vent valve is sealed at all times. Run a 50/50 mix and don't use the sealing tablets.
There is no advantage to DexCool other than the aledged longer replacement interval. I've never made two years in my truck. Dexcool is 90+% the same stuff as Green (ethelyne glycol), but the corrosion additives are vastly different. According to Texaco, it can be mixed with green, it just won't last 5 years. They also say it won't last 5 years in an engine that did not come with it stock.
Pete
