I dont know anything else specifically that would only shut off the lights with the headlight on position so I would think to replacing the headlight switch. Sounds like there is something worn inside of it. Try turning on the headlights and courtesy lights and jiggle the **** around to see if they might flicker.
Hope you figure it out and Good Luck!!
