left bank O2 sensor replaced twice in one year LT1
I had to replace the drivers side O2 sensor again today. Last time I did it was in January of this year. Both sensors had a fair a amount of black soot. I replaced the plugs a few weeks ago and they all looked good. Fuel pressure is at 43PSI. What do you think can be the problem?
how are your injectors? how long does your fuel pressure hold after shuting down? does your vacumme line on your fpr smell of gas? could your cat be pluged up a bit? do you drive like a old lady?
The injectors are probably wore out. The fuel pressure held well for 5 minutes. That's when i disconnect the guage. Should I have held it on longer? The cat is probalbly full of that crap. I'm the 7th owner.
I don't think it's anitfreeze. I Don't add any.
No vac leaks that I can see.
These are all good suggestions.
I do not use any silicone or anything else to that matter. Not even fuel injector cleaner.
I am leaning on vacuum leak or faulty injectors. Probably way to much fuel causing black soot.
get a cheap cigar and blow smoke into the hose off your brake booster into the engine and see where it comes out.
OK, H44 is an O2 sensor left bank, sensing a lean condition.. too much Oxygen in the Exhaust. The PCM is trying to adjust for this by increasing the fuel..
I just had this problem on an 1998 Malibu, it was a P0171. turned out to be a bad Vacuum Cap on the intake manifold..
It could be as simple as a piece of crap Chinese made O2 sensor that just went bad...With most of our parts coming out of China now, I'm seeing more and more parts that are bad right out of the box , or that go bad in a short time ..Now days if something doesn't work when I replace a part, a bad part is the first thing I suspect.....WW.
