Does Anyone's Computer Get Hot?
Old Aug 27, 2002 | 10:00 PM
No Go's Avatar
No Go
Default Does Anyone's Computer Get Hot?
On my 96 LT4, I've noticed the computer is very warm-nearly hot to the touch after driven. It appears to have a heat sink or cooling fins molded into the metal top piece so maybe normal.
I'm just wondering if this is normal/common knowledge???
Old Aug 28, 2002 | 01:23 AM
drive it's Avatar
drive it
Default Re: Does Anyone's Computer Get Hot? (No Go)
Yep, don't worry 'bout it-they all get "warm"!
Old Aug 28, 2002 | 08:27 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Does Anyone's Computer Get Hot? (drive it)
You bet they get hot...that's why the heat sinks are there. On a warm summer day just spray a little non-stick on it and you could fry an egg!
Old Aug 28, 2002 | 09:57 AM
Carl90's Avatar
Carl90
Mine gets hot.
Whenever, I get a chance, I pop the hood to let the hot air escape when I park the car. I think that the temperatures get to the highest levels when the car is stopped. The computer and alternator get heat soaked. Just opening the hood a little helps to reduce underhood temperatures, which should help to increase the life of the electronics.
Old Aug 28, 2002 | 10:03 AM
C4SMAJ's Avatar
C4SMAJ
Default Re: Does Anyone's Computer Get Hot? (Carl90)
...I always have the hood open when its in the garage...just to do as Carl90...let some of that heat outa there..... :seeya
Old Aug 28, 2002 | 03:05 PM
GlockLT4's Avatar
GlockLT4
Default Re: Does Anyone's Computer Get Hot? (larryf)
Always hot :yesnod:
Old Aug 28, 2002 | 03:40 PM
Black96Corvette's Avatar
Black96Corvette
( No Go ) Don't you think your RWHP is significantly LOW for a stock LT4? (260). With a hotcam LT4's should be putting 310 RWHP to the road, and you have corsa you should have serios power. I thought stock LT1's had more RWHP stock than 260?
Old Aug 28, 2002 | 06:45 PM
85vetteguy's Avatar
85vetteguy
:yesnod: Very hot!!
Old Aug 31, 2002 | 07:48 AM
JP's C4's Avatar
JP's C4
Yep! You could use a old PC fan and have installed blowing on the computer. It should help.
Old Aug 31, 2002 | 07:44 PM
No Go's Avatar
No Go
Default Re: Does Anyone's Computer Get Hot? (JP's C4)
I have no worries if others are similar. Just touched it one day after hard run and never noticed it before...wondered if it was going to dump!
To Does Anyone's Computer Get Hot?
