i had a question concerning 396 stroker motors. i friend of mine said that just stroking a 350 block would make 383 and a bore and stroke would make a 386. what exactly are you guys doing to get 396? boring a hell of a lot more out? putting a much larger crank in there or what? im not quite sure i understand all the details a little info would be greatly appreciated
Caboboy is right it is a 350 bored 0.030 over and it had a carnk with a little more stroke then a 400 crank (400 crank 3.75 the other 3.875) you have to clear the block for both and yes a little more for the 3.875 but it is not to much.
Should be a nice motor when you're done with it though Joe.
About 800 HP & 740 lb/ft nice.... :yesnod: Can't wait to get it done. The worst part is I still won't get to put it in. I'll need to beef up the rest of the drivetrain before it goes in. :(
We used a "standard" block for it...just happens to be a Bow-Tie block is all :D
You have to be careful with the rod bolt to cam lobe clearance in a long stroke motor like that. Roller cams can and usually run a smaller base circle than flat tappet profiles and that makes it more compatible with that combo, but you need to take it into consideration when building one.
or........... a 4.155/3.875= 420 which is MY new motor :D
Joe, I don't mean to intrude too much on this post, but how far along are you on your block? What are you using for a rotating assembly? IM or EM me if you would please. I'm ALWAYS interested in talking 400 block stuff. :cool:
He has already built this exact combination with a carb, and heads flowing about 50 CFM less than mine. It's in a Camaro around town and cranked out 760 HP & 680 lb/ft on the engine dyno. It has been raced extensively and has been in the car for almost 2 years now.
The small base-circle cam is the way we have to go. Tolerances are tight, but we'll get there. Thanks for the warning, but we already talked all that through. We'll go with shaft-mounted rockers in a 1.7 or 1.8 ratio to get the valve lift needed to feed this thing air. With that ratio we can go with a smaller grind on the cam...it's all going to be solid-roller.
4.185 bore, 3.48 stroke = The better 383! Just started building this combo for guy. Great rpm/ high horsepower, hoping for 2hp/ci! Also been working on a little stroker for myself, a 352! 4.155 bore, 3.25 stroke(327ci crank), this thing will be a very high rpm/ high horsepower buzz motor!( I hope! :D )
