Engine casting number
Old Aug 28, 2002 | 08:22 AM
shotgun_000's Avatar
shotgun_000
Default Engine casting number
I found this number on the block(passenger side): 14088548
Accoding to one source, the year is 86-94.
According to another, it is 86-88
I can't go by the year of my car, mine is a C3
The problem I am having is with buying parts. I've been told that this engine is an 87 model, but 87 seems to be a pivotal year.
The heads look like they are aluminum. The intake looks like the old style intake, used on older 350's (I'm running a Q-Jet).
So, does this engine have a roller cam?
If so, do I buy a roller cam for 87-up? Or 87-earlier?
It seems to me, since the intake is the older style, then I should buy a cam for 87-earlier.
Can someone clarify?:confused:
Thanks! :cheers:
Old Aug 28, 2002 | 11:31 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Engine casting number (shotgun_000)
Yes it has a roller cam and can buy the '87 and later parts.
Sorry, I'm not sure if the intake makes a difference when selecting a cam. Another topic I will keep an eye on and learn from. ;)
[Modified by War Machine, 9:32 AM 8/28/2002]
