Digital Dash Question
Old Aug 28, 2002 | 11:36 AM
brookman's Avatar
brookman
Default Digital Dash Question
When the dash starts up it is relatively dim - after it warms up or gets bounced around (I don't know yet) it gets brighter. Even when it does brighten up the left side is brighter than the right side. I read somewhere about a problem where pins come unsoldered on the circuit board. Does this sound like the same problem?
Old Aug 28, 2002 | 11:48 AM
hz900's Avatar
hz900
Default Re: Digital Dash Question (brookman)
If the pins are coming unsoldered then the turn signals and high beam indicator will be lit up all the time.
Old Aug 28, 2002 | 11:55 AM
buzzbomb's Avatar
buzzbomb
Default Re: Digital Dash Question (hz900)
When the soldering went bad on mine, the turn signals and high beam light weren't on, but the soldering job fixed it and now it works great. However, the other symtoms don't seem to fit. Here is the repair link http://batee.com/corvette/
Old Aug 28, 2002 | 12:40 PM
jfb's Avatar
jfb
When the pin closest to the center of the circuit board becomes unsoldered the 4 lamps that illuminate your cluster go dark. There is a single row of pins on the front (of the car) board that plugs into a socket on the rear board. The pin becomes unsoldered because of the age relaxed spring on the socket.
Old Aug 28, 2002 | 03:02 PM
vettmech's Avatar
vettmech
Default Re: Digital Dash Question (jfb)
If just one side is going dim it may be bulbs. if that's it, it isn't a big deal to fix 'em......... if you get in there make sure you don't touch them with your fingers because the are halogen and will get ruined. also there are metal sheilds in front of the bulbs. if you remove them and turn on the key ...... you could be "blinded by the light" ........he he :yesnod: :lol: :seeya
To Digital Dash Question
