1985 Corvette Main Cooling Fan Problem
Check your a/c fan request pressure switch, there are two close together. the high press switch has two spade terminals, beside that is the fan request switch (has a small round connector) if that is unplugged it can run the fan whenever the ignition is on.
Have a look at the wiring diagram below to fault find.
Either the a/c fan request switch is faulty, ecm fault or if your car has only the single fan (no booster fan in front of a/c condenser the temp switch in the head can run the main cooling fan. on the booster fan type that temp switch runs only the booster fan.
The ecm grounds the fan relay (or in single fan the override switch in the head).
Dual fan diagram.
Single fan diagram. The fan override switch is in the head (Passenger side on some) has a single wire with a round connector.
My question for ChsTitans: Is your a/c control ON before you start the engine?
Am I correct in assuming that the little fan in front of the condenser is just like an emergency fan, NOT an A/C fan? I assumed that was for extra cooling when the A/C is turned on, but I guess the A/C when on will trigger the main fan. Learn something everyday.
Either way, I have the main fan running at all times.
I'd suspect a bad High Pressure Switch in the a/c compressor. You'll need to put a jumper across that switch to simulate a "closed" switch. When this switch "opens", it tells the ECM the a/c pressure is high, which turns on the main fan.
here is the sensor that was acting up for me. when i jiggled this sensor, the plug, it would activate the fan. sometimes when i started the car it would be on, sometimes not.
it was cliff harris in another thread whi drew my attention to it. i spread the plug pins a bit to make sure there was better contact in the plug. my sensor was good but because the "open" ground position turns the fan on, when my plug pins lost contact, the ecu saw "open" on that circut and on went the fan. when it was cold on startup it would happen alot. then as the engine bay warmed up the pins contacted the switches plug which was off because i didnt have defrost or ac on...the fan would turn off.
i also put some dielectric grease, silicon grease, on my ug connection.
hooefully that is your issue. you can test it easilh enough.
careful with the plugs release. the old plastic is brittle. also it will only go back in one way, line up the slots.
cheers and hope this easily fixes your issue.
note that its possible the pressure switch itself has failed in the open losition. my guess is you could ground the plug and shut the fan off. then if you unfround the ug it starts again that would imy its related to the ac switch. if you ever so slightly bend the tabs a bit (like...barely...just to make contact) and the fan still remains on, then its probably the switch that is stuck open, not a faulty connection from the switch to the harness.
also note, im not an expert by any means on this electrical stuff, so look for the troubleshoot orocedure with the ac pressure switch elsewhere to make sure what i have said is correct. i can verify its what worked for me but im not an expert.
(for example, i never "closed" the circut back to the ecu when the plug was unplugged.....but that theory of narrowing it down mighg work).
sorry to be wishy washy.
VikingTrad3r
passenger side, for orientation, thats the dipstick tube, sans the dipstick, to the left of the exhaust manifold flange on the y pipe.
or on defrost
