time for a rebuild
Old Dec 22, 2015 | 10:32 AM
aklim's Avatar
aklim
Originally Posted by mtwoolford
Reuse your crank. If you want 10:1 compression you'll need new pistons. Most piston sets come with rings. Have the block bored / honed as appropriate.
You can reuse the rods but if you intend on having them resized / rebuilt you'll soon come to the conclusion that new rods are an inexpensive alternative.
Take everything, damper, crank, rods, rod bearings, pistons, rings, flywheel / flex plate in and have it balanced as an unit. The result will be a very nice rotating assembly that won't break the bank.
Personally from your posts, I'd forget about the lower engine, unless of course you find excessive wear or damage to the cylinder wall. Pull the heads, have the heads rebuilt, get new head gaskets, and reassemble the engine. Then drive it until it starts to show excessive oil consumption or blow by past the rings, which could be another 100,000 miles down the road.
Take a good look at the cam and lifters, they don't last forever and if either show any sign of wear, replace them.
I'd have it magnafluxed at the least seeing the age of the car. Stock cast crank of that vintage, I'd get a new one that is better. GM didn't run itself so far into the ground that it needed government help by chance. If you are going that far, probably might as well rebuild the bottom end to a 383.
True,
If you rebuild, you might as well balance the assembly. It can't be that expensive when you consider how many rotations the motor has to go and the better longevity you get.
Agreed. Except for the fact that I don't trust the OEM short block. They weren't engineered to last. I had oil consumption in 2 L98 motors under 100K. Of course, I do beat them so you can granny it and make it last.
Cam I would check the spec if I were so inclined to reuse. Lifters go into the trash.
Old Dec 22, 2015 | 12:26 PM
mtwoolford's Avatar
mtwoolford
Any time you start mixing and matching after market parts, on an engine that gonna see any RPM's at all, the lower end should be balanced....probably true with OEM parts too.
The reason I mentioned the cam is that the surface on the cam lobe is only hardened for a couple of thousandths deep...once the wear gets past that, the soft metal underneath erodes away very rapidly...same thing for the rollers on the lifters.
Old Dec 22, 2015 | 12:36 PM
aklim's Avatar
aklim
Absolutely. However OEM isn't worth the money to balance unless you are looking for originality.
I'm sure the lifters are OK most times but seeing as how you have to remove it to get at the cam, I'd hate to have to go back in to replace the lifters. If they were solid, fine. Hydraulic rollers, I'd probably not chance it on a 30 you motor.
Old Dec 22, 2015 | 05:34 PM
Shank's Avatar
Shank
7th Gear
The OP's handle is "rather b driving". if that's true, imo you should replace the head gasket and drive it. save the cam and the pistons until you have the money to buy what you want, be it an upgraded engine, or an upgraded car.
Old Dec 23, 2015 | 04:33 PM
rather b driving's Avatar
rather b driving
thanks for the advise everyone. I was thinking 'I've gone this far, why not a fat cam ....? After reading this feed back I will probably just do the head gaskets. it ran fine before this , I am going to put it back together properly, drive it little and put it up for sale in the spring. I may look at a c5 then . Are they that much faster, or easier to mod ?
Old Dec 23, 2015 | 05:30 PM
aklim's Avatar
aklim
Nothing is easy to mod. Unless you have something unique and desirable, hence valuable, cars, as a rule are a black hole. You drop money in and you see nothing coming out. So, do you really want something fast? If so, are you able and willing to shell out money and not see ANY return but your own satisfaction? Cars are like hookers. At the end of the session, the best you can hope for is a grin on your face and a lighter wallet. You will have nothing substantial you can take home. So, before you worry about a C5, C6, etc, realize that.
Old Dec 24, 2015 | 07:07 AM
Joe C's Avatar
Joe C
- smart move - with the C5 thing. from a technical standpoint, in stock form, a faster car, but easier to mod - ??? - probably, but I really don't know. ultimately, what are you going to, or what do you want to do with the car? think out the "mod" thing. if your everyday thing is daily driving, and an occasional Saturday night cruise-in, leave it be. keep it clean, well maintained and in a proper state of tune, and enjoy the car. as said, a C5Z in stock form is a great bang for the buck, and will probably outperform 99% of all the cars on the road. more performance than most people will ever need! unless you are serious about tracking the car, are knowledgeable and talented with deep pockets, then have at the mod thing. however, note a few key words in some of the posts - black hole - money pits. (BTW, just my opinion and 2-cents, FWIW).
Old Dec 24, 2015 | 09:52 AM
aklim's Avatar
aklim
Don't know about tracking the car. I haven't done autocross since 2000 and quarter mile every few years. I however enjoy the vulgar power when I am at a ramp. I wouldn't say I have deep pockets either. You are right, it is more than I need. In fact, all I need is really the wife's S320. I want this modified Vette. I drive it whenever it is summer and I can. I don't cruise with anyone.
Old Jan 6, 2016 | 04:08 PM
GJ Camacho's Avatar
GJ Camacho
Default The Cam specs
thanks Aklim,
I would like to know how much lift cam the stock heads take ? 480 ? I am looking at rebuild kits n such to get a good idea of whats what. A comp cam I am interested in advertises 480 int / 488 exh lift . Could the stock heads work with that without binding or spring problems ?
Original cam: 203 208 114* 449 459
CompCam: 210 220 114*500 510 p/n 07-304-8 for stock LT1, according to compcam a "noticeable increase over stock cam". Go to their page to verify. I have a 93 C4 and dropping in a top end kit rated at 430HPs. Once you start it doesn't get any cheaper... trust me.
Old Jan 6, 2016 | 04:48 PM
DGXR's Avatar
DGXR
Save the money for something worthwhile like Hooters and booze.
I found my new signature tagline.
