I replaced the old balancer, because the rubber was old and it was wobbling. I put the new one on and everything looks good. I have it torqued to spec.
Now I didn't have to press the balancer on. it slid on snug.
The Chilton Manual say to remove the balancer I will start at step 10
Unfasten the balancer bolts/screws, then remove the balancer assembly.
The manual only states to remove the hub with a removal/ installation tool. To install: use the removal/ installation tool.
To install the balancer: Install the crankshaft balancer and retaining bolts/screws. Then tighten them to 60 ft lbs and the hub bolt to 70-75 ft lbs.
So, I am assuming that the balancer should go right on ( like it did ) and is not a pressed on fit ( like the hub ).
Also, looking back at the vin 8 directions the dampener and hub was one piece. and required the entire thing to be pressed on.
Yes the balancer just gets bolted onto the hub snout on a LT1/4 and is not a press fit. One thing however, if you haven't reassembled everything, take it off and put some anti-seize on the surfaces that contact the hub when it is bolted on. That way if you have to remove it again for opti service in a few years, it won't rust-weld itself onto the hub.
Nah, Tom, you're not corrected. You are correct. I just find the use of terminology funny. It's a "dampener" or "damper" as you said. It's strange that GM just continued to call it a balancer. I guess it made it easier for them.
I think they continued to call it a "balancer" since it is short for "harmonic balancer". Although it doesn't balance the engine, it does dampen or balance the harmonics or rotational vibrations.
I have seen it both ways so often, it doesn't matter, we all know what the part is.
