no turn signals
Old Aug 29, 2002 | 12:46 AM
Onyx's Avatar
Onyx
Default no turn signals
The other day I noticed my interior turn signal indicator arrows were no longer lighting up in either direction. Sure enough, all my exterior turn signals refuse to flash.
I've checked the "turn" fuse in the fuse box and it's fine. is there something I can do to test the switch? Does anybody have any other suggestions?
thanks!
Old Aug 29, 2002 | 01:05 AM
jfb's Avatar
jfb
Default Re: no turn signals (Onyx)
When you use the turn signal switch do the turn signal lights stay on? I would check the flasher its probably toast.
Old Aug 29, 2002 | 03:25 AM
Onyx's Avatar
Onyx
Default Re: no turn signals (jfb)
yes, the lights stay on. just no flashing. hmm...it would probably make sense to check the flasher. :lol:
thanks jfb
Old Aug 29, 2002 | 04:44 PM
Rick86's Avatar
Rick86
When you turn your head lights on do any of your turn signal arrows on the dash stay illuminated? If so then its a ground issue. Usually at the harrness were it plugs into the turn signal. Try giggling the wires around and see if they start working. That was the problem I had with mine.
To no turn signals
