1986 Digital Cluster Pulsating Problem
Old Aug 29, 2002 | 09:52 AM
Bob Czar's Avatar
Bob Czar
2nd Gear
Default 1986 Digital Cluster Pulsating Problem
:eek: Last year I installed a reconditioned digital cluster
I purchased from Gene Tabor for my 1986 Convertible.
Lately when driving the car at night the cluster is pulsating.
Any thought on what might be causing this problem?
Old Aug 29, 2002 | 10:34 AM
GS-598's Avatar
GS-598
Default Re: 1986 Digital Cluster Pulsating Problem (Bob Czar)
I had an 86 several years ago that did this. I could also see similar pulses on a voltmeter connected to the battery. When the alternator failed, and was replaced, the pulsating was gone. My guess is that the pulsating you see is related to the voltage regulator.
Good Luck
:cheers:
Dennis
GrandSport #598
Old Aug 29, 2002 | 11:33 AM
jmrl98's Avatar
jmrl98
Ny "85 did the same thing - and it was my battery. So it is probably something electrical. It only was noticeable at night like yours, and at first I thought it might be the photocell in the dash. But it turned out to be the battery. :seeya
Old Aug 29, 2002 | 11:34 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: 1986 Digital Cluster Pulsating Problem (GS-598)
Good Luck
:cheers:
Dennis
GrandSport #598
:yesnod: I'd check that first as well. Good luck finding your problem.
Old Aug 29, 2002 | 12:03 PM
scorp508's Avatar
scorp508
Same thing with mine. When the alternator starts to go she starts pulsating.
Old Aug 29, 2002 | 01:12 PM
jfb's Avatar
jfb
The voltage regulator in your alternator is oscillating. If you look at the waveform across the battery you will see it. With the engine off, you will not see the pulsing, nor when the engine is running and you pull the plug on the alternator. Its time for new alternator.
Old Aug 29, 2002 | 04:37 PM
Rick86's Avatar
Rick86
Default Re: 1986 Digital Cluster Pulsating Problem (jfb)
When my dash decides to go Disco on me I tap the glass to remind it that this car is a no Disco zone, she usually listens.
Old Aug 29, 2002 | 04:50 PM
ZylaRace's Avatar
ZylaRace
Default Re: 1986 Digital Cluster Pulsating Problem (Rick86)
Same,.... Alternator went south.
Old Aug 29, 2002 | 06:03 PM
Schwaggs's Avatar
Schwaggs
Cruising
Default Re: 1986 Digital Cluster Pulsating Problem (ZylaRace)
Same, Alternator rectifier went bad. Take the alternator off and take it to a quality autoparts store and have it tested. They can tell you if the rectifier is good or not. You can also see this on some GM cars in the tail lights, they seem to pulse brighter and dimmer. I had my alternator rebuilt by a local company for $20. This way I make sure I don't inherit someone else's "lemon".
BTW, the rectifier is what converts the AC voltage to DC. When part of the rectifier dies, you might be passing AC to the rest of your car. This is one of the things you need to fix sooner, rather than later to prevent damaging other components.
Old Sep 3, 2002 | 07:25 PM
Bob Czar's Avatar
Bob Czar
2nd Gear
I just re-installed my rebuilt alternator and it did not take care of
the pulsating problem. It seems to pulsate at night and not during the
day. At least I know my alternator is in good shape. I installed an after market stereo this year. I wouldn't think that is causing it. Any other suggestions would be apprecited :confused:
[Modified by Bob Czar, 11:27 PM 9/3/2002]
Old Sep 3, 2002 | 07:31 PM
vetracer's Avatar
vetracer
Mine has done the same thing off and on in my 86 and my electrical system is totally stock. I noticed that the cluster auto dimmer light sensor (that little square eye near the odometer) doesn't seem to be working. Maybe that has something to do with it.
Old Sep 3, 2002 | 09:56 PM
dbwade36's Avatar
dbwade36
Mine 86 Cluster when nuts one day, then completely out! The next day, I started the car and it worked fine. It hasn't messed up once since then. Talk about wierd!
To 1986 Digital Cluster Pulsating Problem
