1984 Electrical Problem
Old Dec 24, 2015 | 05:19 PM
Brxndon's Avatar
Brxndon
Default 1984 Electrical Problem
To start off with Merry Christmas Guys.I got my corvette in August every month i have tried to figure out what is wrong with her. The car drains the battery whenever the terminals are on. I got the Battery and alternator checked and both checked out to be working. I also thought it was the aftermarket radio my grandfather put in, so i took it out and still it continues to drain. Do you guys have any ideas? please help me out i've ran out of options. I'm also 17 and my resources are limited. again Merry Christmas.
Old Dec 24, 2015 | 06:10 PM
1984Z51auto's Avatar
1984Z51auto
The best/only good way to find the battery drain is to get a Volt-Ohm Meter (VOM) and test each of the circuits at the fuse box. A VOM is a basic electrical tool you will need in future to test many things so... get a decent one, they are not expensive. Hook up the battery, turn everything off and pull one fuse at a time from the fuse box, checking for current in each circuit. You expect current in the clock and engine control module (ECM) or computer circuits. If you find a current drain in other places that may be the problem. The security system has a fuse behind the center console panel Driver Information Center (DIC) and is a bit involved to get to. Once the checks are done, you can identify the area of the problem and go from there. Let us know the results of your fuse box test. What do you mean "terminals are off"? If the battery drains quickly while both terminals are off it has an internal short or is so dirty that current is flowing between the external terminals.
Old Dec 24, 2015 | 06:28 PM
Brxndon's Avatar
Brxndon
My mistake I meant to say on*.
Old Dec 24, 2015 | 06:51 PM
1984Z51auto
OK so the first thing you need to do is isolate the circuits where there is a current drain when all switches are "OFF". That includes holding in the door switches as there is a delay timer on the interior lights which could give a confusing indication.
Old Dec 24, 2015 | 07:06 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Are you sure all of the lights in the car are turning off when they should? Under-hood lights? Console light? Passenger sunvisor lights? Interior courtesy lights?
Does your horn work? Radio antenna? Headlight motors? Does your radiator fan work properly?
Anything else unusual about the car?
Old Dec 24, 2015 | 07:25 PM
Brxndon's Avatar
Brxndon
Evrything works perfectly and everything turn off when they should. I will be sure to try the Fuse thing when I have a chance. I'm just trying to get her back on the road.
Old Dec 25, 2015 | 02:47 AM
Cliff Harris's Avatar
Cliff Harris
You can find which circuit is using power by measuring the voltage across each of the fuses. It's going to be very small, so use the lowest voltage range. If there is a power draw on a particular fuse, the voltage will be VERY SMALL, so measure carefully. Remember that the interior lights will be on since the door is open.
See this video for help with your problem (the fuse voltage method starts at 11:30 in the video):
Usually a parasitic draw is caused by a motor that should turn off but doesn't. Likely suspects are the antenna, power seats or headlight motors.
Old Dec 25, 2015 | 02:45 PM
1984Z51auto
https://www.youtube.com/watch?v=P-wxG6U5TuY
The door lights being on is why I told the OP to hold in the door switch. Once the OP reports on the circuit(s) with a drain it should be easier to identify what is going on.
To 1984 Electrical Problem
