Removing 93 6 speed lever
Old Dec 26, 2015 | 02:48 PM
Herb's Avatar
Herb
Default Removing 93 6 speed lever
I'm trying to pull the engine on the 93 LT1 and the six speed lever is in the way how do I remove the six speed lever?
I just don't know if I can tilt the engine enough so the shift lever will clear the
interior of the car as I'm pulling the engine.
I guess I'll have to wait until Monday to find out.
The hoist I rented would not lift the engine because of a bad hydraulic leak and
They are closed on Sunday.
Old Dec 26, 2015 | 02:54 PM
antfarmer2's Avatar
antfarmer2
one post is enough they will get to you youtube will get you started
Old Dec 26, 2015 | 03:00 PM
Herb's Avatar
Herb
Default The number of post is because of editing.
Once you edit it there is nothing to click on stating re post.
So I would get out and look to see and there would be nothing there so I would go back in and try it again.
Not a very friendly site to make corrections or to add attachmentsi
Old Dec 26, 2015 | 03:01 PM
antfarmer2's Avatar
antfarmer2
Gear shift **** removal.
I'm stripping the interior on my 1995 Convertable and am down to the console part. How does the six speed gear shift **** come off ? Is it pressed on or does it screw off ? It's REALLY on there tight and I don't want to break it. I'm going to have to exert a LOT of force either way. .Jimbobc4**rrubel*said:06-05-08*08:17 PM
http://www.redlinegoods.com/C4install.shtmAnd their products are good, too (you can see mine in the 2nd picture down).[RICHR]
Old Dec 26, 2015 | 03:10 PM
antfarmer2's Avatar
antfarmer2
once you edit just hit save. click on the link above I believe that will help
To Removing 93 6 speed lever
