Fuel Pump????
Old Jan 3, 2016 | 07:55 PM
Doug Crow's Avatar
Doug Crow
Default Fuel Pump????
My 1994 Corvette was acting like it was flooded when trying to start. I would prime it 3-4 times to get it to start. Ended up replacing the fuel pump and seemed to fix the problem. However month later I am getting the same thing again. Started one time and died when I hit the gas. Now just acts like it is flooded.
Any thoughts?
Old Jan 3, 2016 | 09:10 PM
Mishawaka's Avatar
Mishawaka
Read that wrong, sorry for what I wrote at first. Have you checked the fpr, injectors, and a good blue spark at the plugs?
Old Jan 3, 2016 | 09:27 PM
antfarmer2's Avatar
antfarmer2
pull the vacumme line and smell for fuel.
Old Jan 3, 2016 | 11:26 PM
Cliff Harris's Avatar
Cliff Harris
Any thoughts?
Your post is contradictory. You said "flooded", which is too much fuel. Then you said you primed it several times, which sounds like not enough fuel.
If it's really flooded, hold the accelerator pedal to the floor while starting. That will put the ECM in "clear flood" mode, which basically turns off the injectors.
Old Jan 4, 2016 | 06:22 AM
TorchTarga94's Avatar
TorchTarga94
What is your fuel pressure?
Old Jan 4, 2016 | 07:08 AM
antfarmer2's Avatar
antfarmer2
and how long does it hold?
Old Jan 4, 2016 | 07:17 AM
TorchTarga94
Also, did you re-use the old fuel pump pulsator? The general consensus around here is that it is not needed on our cars. Ditch it and run submersible fuel line in its place.
Old Jan 4, 2016 | 07:57 AM
antfarmer2's Avatar
antfarmer2
or used the wrong hose.
Old Jan 4, 2016 | 11:28 AM
Doug Crow's Avatar
Doug Crow
You are correct. Sorry for the confusion. I will try that later and let you know.
To Fuel Pump????
