Total timing
Old Jan 5, 2016 | 12:12 AM
mlm0's Avatar
mlm0
Default Total timing
Can the total timing on 89 l98 be set or does computer do that based on static timing set point?
Old Jan 5, 2016 | 12:22 AM
DanielRicany's Avatar
DanielRicany
You can advance it at the distributor, however, that's not the proper way to do it. The proper way to do it is to advance it in the correct load areas in the tune.
Old Jan 5, 2016 | 12:37 AM
aklim's Avatar
aklim
AFAIK, the computer advances it from the tables. In my case, my base timing was 0 and the chip was set to advance it based on what the tuner programmed. I don't think it matters much which way to the tuner.
What are you trying to achieve?
Old Jan 5, 2016 | 12:48 AM
mlm0's Avatar
mlm0
I was doing some reading it said the 350 runs best at 36 degrees total timing I didn't know if that was something I could Check and try it
Old Jan 5, 2016 | 12:52 AM
aklim's Avatar
aklim
Even if you could change total timing, how would you check it if it runs best? If you had a dyno and a wideband O2 sensor, probably. If you want to optimize it, best get a dyno tune. When they did my chip, they would see what the dyno read, tweak it, rerun it till the power drops off and use the O2 sensor to check the rest. IIRC.
Old Jan 5, 2016 | 01:03 AM
mlm0's Avatar
mlm0
You are right, I would not know. Wish I could get a dyno tune
Old Jan 5, 2016 | 01:21 AM
aklim's Avatar
aklim
Depends. Have you done any substantial mods? If not, I don't know it will be worth it unless you have more money to burn than brains. With a stock system, it has been said to not have that much effect. Say you throw in a much better intake and headers, your curve has changed so it is somewhat justifiable. If you throw in heads and cam, definitely.
Old Jan 5, 2016 | 02:26 AM
Hot Rod Roy's Avatar
Hot Rod Roy
That last ounce of performance requires a dyno tune! Do you really need that last ounce? How deep are your pockets? With a modestly modified engine, you may not be able to detect any improvement in performance!
Old Jan 5, 2016 | 06:18 AM
Joe C's Avatar
Joe C
is the 36 degrees governed by the ECM? to me, that would make sense IF the initial timing is set at the factory specified 6 degrees BTDC.
Old Jan 5, 2016 | 11:10 AM
mlm0's Avatar
mlm0
Sounds like I got my answer
Thanks to everyone
Old Jan 6, 2016 | 12:53 AM
Cliff Harris's Avatar
Cliff Harris
Yes.
The ECM assumes the initial timing is 6°. You can change the 6° in the tune if you feel compelled to change the initial timing. The ECM adds the appropriate value it looks up in the timing tables to the initial advance. The ECM also has a maximum advance parameter and will not advance the timing more than 42°.
Old Jan 6, 2016 | 01:21 AM
mlm0's Avatar
mlm0
Good info. Thanks
Old Jan 6, 2016 | 10:34 AM
Joe C's Avatar
Joe C
Originally Posted by Cliff Harris
Yes.
so, IF the max ECM advance is 42°, then I can assume the maximum, initial advance would be 12° BTDC? I may be totally out in left field with my thinking, but does a SBC have a limit of 30° net, advance timing (total less initial) - ???
Old Jan 6, 2016 | 11:01 AM
aklim's Avatar
aklim
IF I am reading him right, the ECM assumes you started at base based on the program you wrote. If it advances a max of 42, your total advance is (6+42) 48. Whether you reach that point or not depends on your KS and whether it is picking up knock. IIRC, it will retard timing till it hears no knock.
Old Jan 6, 2016 | 12:15 PM
DanielRicany
I'll try to break it down. Stock BASE timing is 6*. In the tune, if you were to set one cell in the timing table to 36*, then the ECM would do the following formula. 36 - 6 = 30, advance timing by 30*.
You can change the base timing in the tune from 6 to whatever you want it to be, but it's kinda pointless unless you are tuning your cranking timing, in which 6* is perfectly fine from what I have experienced.
Old Jan 6, 2016 | 02:41 PM
Joe C's Avatar
Joe C
as I said, I may be out in left field in my thinking, but if the initial advance is 6 degrees BTDC, then the ECM will limit the total advance to 36 degrees (36 - 6 for a total of 30). if the base timing is set to 10 degrees BTDC, then the ECM will limit the total advance to 40 degrees (40 - 10 = 30). for some reason, i'm thinking all timing has to be within a 30 degree window. based on what Cliff stated, "the ECM ALSO has a maximum advance parameter and will not advance the timing more than 42° (total)," BUT I'M THINKING will LIMIT the total advance to 30 degrees plus initial, at any given time. about 55 years ago, someone tried to explain to me the whole 30 degree window thing, although i'm not sure I fully understand the technical aspect on timing and advance -
Old Jan 6, 2016 | 03:19 PM
DGXR's Avatar
DGXR
Besides the KS feedback, I understand that RPMs, engine load, throttle position, MAF feedback, fuel injector pulse, and other parameters are also factored into the amount of timing advance given by the ECM. May be inconsequential to the discussion at hand, but wanted to chime in.
To Total timing
Old Jan 6, 2016 | 03:36 PM
Hot Rod Roy
I don't think there's any way the ECM can know what you've set the initial advance to. It only looks at the parameters of the performance (temp, vac, O2, rpm, MAF, throttle position) and sets the advance (and fuel) according to its program. If it sees knock, it retards, but if no knock, no retard.
How can it know what the initial advance was set to? There's no way it can even know TDC (L83 & L98. LSx engines may be smarter.)!
So, if you've set initial advance to 6*, and the program says +30*, you get final advance of 36*.
With initial advance of 10*, and the program says +42* (max, per Cliff Harris), you get final advance of 52* (less knock, if detected).
If the ECM was smart enough to know I've set initial advance to something other than the stock 6*, why can I feel the difference in performance of 6* vs. 8* (SOTP test)? If the ECM was smart enough to know the initial advance was something other than the recommended 6*, it wouldn't even care where you set the initial advance! It's just not that smart!
Old Jan 6, 2016 | 03:43 PM
DanielRicany
The main things that come into play in the timing table are load and RPM. MAF and RPM make up a load value.
Injector pulse has no influence.
KS has influence when there is a signal, and the TPS has influence at WOT where it can either retard or advance timing, however the tuner chooses.
At least this is what happens for an '85.
Old Jan 6, 2016 | 04:28 PM
383vett's Avatar
383vett
In reading this thread, I think some of the posters are not differentiating between wot timing and timing at cruise. The 6 degrees initial plus 30 that the ECM adds for a totL of 36 is for wide open throttle parameters. At cruise, the motor can easily see 45 degrees of total timing. Think of it as a vacuum advance added timing
