Now that I have found a shop in Texas that will do a real time dyno Ecu tune on my 89, I want to do a little up grading. Nothing too wild. I am going to add headers and better exhaust. I don't know much about all this stuff but I wanted to bump it up from 240 to around 300 hp at engine. I was thinking about a different cam also. Don't want to change heads or manifold. I want to keep low end power, but would like a little rumble. Am I wasting my time and money by only changing those things. Tuning is about 450.00 out the door
I think headers/exhaust, cam and tune are a GREAT place to start w/a TPI engine. The stock manifolds and exhaust on a TPI are terrible. Stock cam is pretty terrible. Both places that you can get large gains. Probably the largest gains from a single part other than a forced induction on a stock or stockish TPI motor.
I think you're on the right track and have a good plan taht will result in ~300 hp.
Miniram, headers and exhaust MIGHT get you there if you have an 88-91. With that combo, you probably won't even need a tune. You would lose low end torque though.
If that doesn't get you there, add a cam and you will be there.
Why are you bringing the Miniram into this!?
*The OP clearly stated that he doesn't want to lose low RPM tq AND doesn't want to change intake manifold. You just stated that w/ a miniram, he will lose low end torque, and it's a manifold change.
*How many peak hp will the miniram give him on stock heads? How many will a good cam give (cam will likely give more)
*How about the cost. Cam is ~$300. Miniram w/rails, etc? ~$900 or so?
Totally inappropriate advice for this thread. Cam headers exhaust and tune should get him damn close to 300 horse, IMO.
How many miles on the engine? Me personally, I would either port or replace the heads while your at it and I'm no so sure if I would bother to put headers on it unless your doing more than that.
You could probably get close to 300 with the stock camshaft if you were willing to upgrade some of the TPI, but it would require changing the base, runners, and porting the plenum out. Do all that with the exhaust changes and you should be close to 300 bhp.
You will have to take it all off to get the cam out anyway, though you might be in the hole another $1K to replace and/or port it all out.
Just pointing out that '90-'91 are speed density and a different computer. 85-89 respond better to tuning unless you a real tuner the speed density has advantages over maf.
Several years ago, with the stock L98 with these mods listed below I got 250rwhp/350rwtrq;
cut air filter box, 52mm tb, ported plenum, large tube runners, stock base, March 3 piece underdrive pulleys, air pump removed, stock exhaust headers, front y-pipe without the pre cats, catalytic converter removed, magnaflow rear exhaust.
Dyno Tuned and I had the 3.07 rear axle ratio and 315/35/17 tires.
You are close to me, Georgetown. It's Henderson performance in New Braunfels. I talked to them this morning on phone. On their web site, they did no list c4's, but when I talked to them he said no problem. They real time dyno tune it and then burn a chip with whatever settings make it run best. When I told him I would be getting an OSTRICH in order to real time tune, he told me they use somethings similar Told me roughly 450 out the door unless there are other problems. That price included new chip
If you get headers don't get bigger than 1 5/8 or your mismatching your parts too much, even with a better intake with your goals I'd stick with 1 5/8. Some people size headers to intended rpm and a 350 with 1 5/8 is good some past 6000rpm and your not gonna be there with a mostly stock engine. Some stock eliminator guys run 1 1/2 headers and make over 300hp. You can meet your goal long as you don't mismatch too much. Still once you do all the odds n ends stuff you might see a swapping some quality heads(not over sized) may be cheaper, quicker and easier in the long run.
