C4 HEADLIGHTS
Old Aug 29, 2002 | 11:32 PM
ONEVETTE's Avatar
ONEVETTE
Cruising
Default C4 HEADLIGHTS
I turned on my front headlights after several months of having the car in storage. The headlights popped up into position but I could hear the headlight motor continuing to run for at least 5 additional seconds following retraction. Is this normal? Is there a potential problem with the headlight system? Any assistance would be appreciated in foreseeing future headlight problems due to continuous running of the headlight motor upon completion of retraction.
Keep the wave alive!
'ONEVETTE'
sircaptain@aol.com
"Keep riding it until the wheels fall off.
:seeya
Old Aug 30, 2002 | 12:19 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: C4 HEADLIGHTS (ONEVETTE)
Sounds like you'll need to replace the bushings. My buddy just did both of his in his '88. Since I didn't help him I can't give any pointers, but I will tell you this, it only cost him $5 for each headlight for the bushings.
You can get them in the Mid America catalog.
Old Aug 30, 2002 | 12:21 AM
JonM's Avatar
JonM
Bookmark this page...you will need it
http://www.corvettemagazine.com/2001...ghts/head1.asp
Old Aug 30, 2002 | 10:13 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Check your e mail
Old Aug 31, 2002 | 12:06 AM
65Z01's Avatar
65Z01
Try to move the headlights by turning the manual *****. If movement is immediate the problem is in the motors; if movement is "mushy" change the three nylon bushings as indicated.
To C4 HEADLIGHTS
