LT-1 Coolant temperature sensor location
Old Jan 10, 2016 | 10:52 AM
RVY's Avatar
RVY
Default LT-1 Coolant temperature sensor location
Just WHERE on the (93) LT-1 is the COOLANT TEMPERATURE SENSOR located?
Old Jan 10, 2016 | 10:59 AM
charliet615's Avatar
charliet615
Right in Front of the water pump...........Can't miss it.........
Old Jan 10, 2016 | 11:04 AM
antfarmer2's Avatar
antfarmer2
what one digital is on the water pump analog I believe is on the pass side center of the engine.
Old Jan 10, 2016 | 11:46 AM
Brentwood Sooner's Avatar
Brentwood Sooner
Yeah my 96 is on the passenger side but more toward the fire wall, I is kinda a pain in the but to get too
Old Jan 10, 2016 | 04:26 PM
WVZR-1's Avatar
WVZR-1
ECT for ECM control etc. is of course in the water pump.
What are you attempting to fix? A DTC maybe? Water pump location.
The sender/sensor in cylinder head is for cluster gage only operation. It will be between cylinders 6 & 8. You can't miss it.
To LT-1 Coolant temperature sensor location
