1994 LT1 Driver Airbag
Old Jan 11, 2016 | 08:02 PM
77dreamcometrue's Avatar
77dreamcometrue
Cruising
Default 1994 LT1 Driver Airbag
Hey all I searched the forums and didn't find anything. I removed the two retaining bolts from the driver airbag and it will not come off. Everything I have found suggests it would come right off no such luck. Any advice would be appreciated thanks.
Old Jan 11, 2016 | 08:22 PM
antfarmer2's Avatar
antfarmer2
did you disconnect the power first? you sure there is not four screws?
Old Jan 11, 2016 | 08:31 PM
77dreamcometrue
Cruising
Yes and everything I've seen on here and physically indicates 2 screws...
Old Jan 11, 2016 | 08:43 PM
antfarmer2's Avatar
antfarmer2
I just did my 94 last year and it came right off. did you get something sticky behind it?
ok just went outside and uncovered mine take the other two screws out.
Old Jan 11, 2016 | 08:50 PM
WVZR-1's Avatar
WVZR-1
If you "just did it" how many damned screws did you remove?
OP - There's 4 screws that need to be removed.
Old Jan 11, 2016 | 08:55 PM
antfarmer2's Avatar
antfarmer2
I already told him. who pissed in your cheerios?
Old Jan 11, 2016 | 09:54 PM
77dreamcometrue
Cruising
Feeling a little silly thanks everyone I was working in the dark...
Old Jan 11, 2016 | 09:57 PM
antfarmer2's Avatar
antfarmer2
thats ok good job sorry about the redneck are you replacing your horn buttons.
Old Jan 11, 2016 | 10:15 PM
77dreamcometrue
Cruising
I'm actually trying to see if I can get to the tilt pins to remove the play in my tilt wheel.
Old Jan 11, 2016 | 10:20 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
http://www.zr1specialist.com/HAT%20W...lumn%20pin.htm
Old Jan 11, 2016 | 10:21 PM
antfarmer2's Avatar
antfarmer2
not sure but I think it is the houseing that wears not the pins. look in the stickys and take pics and pay attention.
Old Jan 11, 2016 | 11:28 PM
antfarmer2's Avatar
antfarmer2
good info hope he find this before he goes any farther.
Old Jan 12, 2016 | 11:29 AM
TorchTarga94's Avatar
TorchTarga94
I replaced the left pin with the oversized pin from Haibeck. Helps a little, but there is still play. I think they all have a little play, some worse than others.
To 1994 LT1 Driver Airbag
