Doug Nash 3+4 Tech
I just bought my 1st Corvette, a '86 Coupe L98 w/ the DN 4+3. The price was right and as a ancient auto tech/instructor it's going to be a DD-ish car. I bought it to DRIVE and enjoy.
Now back to my question(s).
The system does not shift into overdrive. The light in the message center comes on but clutching makes no RPM difference. However, when the O/D light is on, backing off the throttle for decal causes the car to freewheel. Clicking the button cancels O/D and the car decels normally. The car also backs up normally. I'm running right at 3k RPM @ 70mph.
I've had the car 2wks and I'm getting ready to service it. I've ordered/received the O/D filter kit and my shop manual CD has come in.
What do I need to look for as I change the fluid/filter? What failures seem to be the most common?
Thanks in advance for the information.
Jonathan.....
Could be caused by poor/irregular maintenance by the PO, or an unaddressed external ATF leak. May also be internal seepage from the T10, though that problem is more common with earlier cars. Supposedly the offending design flaw was corrected before your '86 rolled off the line, but seals do fail...you'll know for sure if there's gear oil in the fluid
If you're feeling lucky and the old fluid doesn't look too bad, replace the filter, fill her up, and pray that O/D engages. If not, you've got more digging to do.
You have to remove the pan to change the fluid. There are two metal lines from the OD unit to the radiator. Disconnect the two lines and use low pressure air to blow out the lines. Then re-connect. Pull the old filter straight down. If the "kit" came with a new rubber grommet, insert it into the hole in the filter and push the filter back on the tube.
When you remove the pan, make sure all traces of old gasket material is gone from both the pan rail and the OD case. Make sure the pan rail is straight with no bends or the holes aren't pushed up from excessive bolt tightening. Remove the round magnet and clean the pan and replace the magnet.
I like to use black RTV sealant instead of the cork gasket. Apply a 1/8" bead around the rim of the pan and around the holes and re-attach to the OD. You don't have to torque the bolts just get them equally tight.
Use DexIII/Mercon ATF fluid that is not synthetic. You will need a pump to get fluid into the OD pan. Get one of the $5.00 Harbor Freight pumps. Once you have the fluid in, with the rear wheels off the ground, turn a rear wheel by hand for about 8-10 revolutions. This will push new fluid thru the two lines that go to the radiator. Then top off the OD unit. Should take just under 2.5 quarts to do everything.
Here's a link to OD operation and common problems.
...but no harm in trying a fluid & filter change, as long as the OP is willing to pay for fluid twice if it fails to resolve the problem. It's a fairly quick job too.One other thing--some (all?) of the filter kits do not include a new grommet, which is critical as it seals the screen and fixes it in place. Be gentle during removal (I wasn't particularly cautious, but I was lucky
), and you should be able to remove the grommet and reuse it in your new screen. If you are not so fortunate, sourcing discussion here: https://www.corvetteforum.com/forums...et-update.html
Does anyone do a quality reman on these units or would I be better served to have mine rebuilt? The o/h kit is $275 plus shipping from Eckler's.
I read up on the FSM and it don't look like it takes too many special tools.
I did the fluid/filter change and the pan was clean w/ no fragments of clutch disc mat'ls showing. System operation didn't change.
OPERATION QUESTION If the O/D light is on, the car will free-wheel on decel when I back off the throttle. Turning off the O/D causes the car to decel normally. Sprag clutch?
got some electrical work to do in that the back-up lamp switch came loose from the switch and the connector melted against the header. There may be a partial break in the wiring somewhere.
Mayhem and misdirection always accompany melted wires and shorts, so you should of course correct that first...then dig into the O/D.
The car backs up perfectly.
I was browsing thru the wiring diagram (the 1st thing I ordered when I got the car was the FSM).
I found the O/D relay and the green wire from the relay to the solenoid branches off to the O/D light. Electrically, I'm down to a stuck solenoid inside the unit or a break in the green wire from the relay to the solenoid.
