A/C drain line stopped up
Old Aug 30, 2002 | 09:56 AM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default A/C drain line stopped up
After finding water in passenger floorboard took 93 Ruby Red to shop and they blew hi press air into drain line and leaves came out along w/ water, however, it stopped back up. Their next step was to remove blower motor and maybe even casing in order to clean it out but I told them I'd do that. Anybody out there had this problem and how did you fix it? Thanks in advance
[Modified by Steve02C5, 7:57 AM 8/30/2002]
[Modified by Steve02C5, 7:58 AM 8/30/2002]
Old Aug 30, 2002 | 09:59 AM
vettmech's Avatar
vettmech
Default Re: A/C drain line stopped up (Steve02C5)
It's pretty common on lots of cars.........there must be a screen or something missing or out of place allowing the leaves to get in there ..... I think I saw someone making a filter for the plenum ....... after you get it cleaned you might consider this :seeya
Old Aug 30, 2002 | 11:03 AM
C4TOMCAT's Avatar
C4TOMCAT
If you pull the motor from the housing, get some clear flexible tygon tubing as large a size that you can work in the a/c cavity. three/four feet is plenty and stick one end in the cavity (maybe use a wood down taped to the end) and the other into your shop vac. suck the dirt and crap right out. you can also flush from the inside by pouring hot water down the tube and make sure the drain is open and clean. good luck
Old Aug 30, 2002 | 11:39 AM
Blue88's Avatar
Blue88
I have had dirt dobbers fly under the car and build a nest in the drain tube and this caused mine to backup.
Old Sep 1, 2002 | 01:02 PM
Steve02C5's Avatar
Steve02C5
Default Re: A/C drain line stopped up (C4TOMCAT)
What is a "wood down"? Thanks
To A/C drain line stopped up
