ramps
Old Aug 30, 2002 | 11:20 AM
larryfs's Avatar
larryfs
Default ramps
I'm a newbie vette owner, LT4.
what is the easiest way to get the front end up on ramps? I tried the rhino ramps with a 2x6 lead, but the spoiler still hit bottom.
any hints on how to get the front end up for an oil change would be appreciated.
thx
Old Aug 30, 2002 | 12:29 PM
HTRK-1's Avatar
HTRK-1
Default Re: ramps (larryfs)
I have to drive up on 2x6's then slide my jack under the front cross member. When the car is up in the air, depending on what I need to do, I set it down on the rhino ramps (oil changes) or slide jack stands under the frame where it bends in toward the engine. Hope this helps :cheers:
Old Aug 30, 2002 | 12:49 PM
FlyboyZR1's Avatar
FlyboyZR1
Drive up on a couple of old math books, and you should have all the clearance you need. It's not a big deal if the spoiler hits, just bends a little bit but bends right back. :cheers:
Old Aug 30, 2002 | 12:52 PM
Lone Ranger's Avatar
Lone Ranger
Rhino ramps work fine. Air dam drags a little but not enough to hurt it.
Old Aug 30, 2002 | 02:01 PM
TA's Avatar
TA
Default Re: ramps (Lone Ranger)
What he said :yesnod:
Old Aug 30, 2002 | 02:05 PM
STL94LT1's Avatar
STL94LT1
Rhino ramps and 2x6's work fine for me.
Old Aug 30, 2002 | 10:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:D :D :D Buy a Kwiklift! :D :D :D
Greatest investment you can make, will pay for itself in 70 oil changes :smash:
seriously, check them out
Old Aug 30, 2002 | 10:30 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: ramps (jackdaroofer)
I'd love to talk the wife into that one! :yesnod:
Old Aug 30, 2002 | 10:51 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: ramps (Hardcorvette)
:jester Just tell her your life insurance and your 401 K don't pay off in the event you die from crawling under your vette without the Kwiklift :D :D
jack
Old Aug 30, 2002 | 11:47 PM
RadPolo96's Avatar
RadPolo96
I just took some wood planks about a foot and 1/2 and proped them up with another small peice of wood. They easily drive up the ramps without scrapin or pushing the ramp.
Old Aug 31, 2002 | 09:31 AM
KyleBst264's Avatar
KyleBst264
I've got the drive up ramps with 6 inch front extensions, the spoiler still hits. to solve this problem, I stuck pieces of wood leading up to the ramps, and it was able to get the front air dam up enough not to hit the ramps.
Old Aug 31, 2002 | 02:25 PM
tkrussell's Avatar
tkrussell
Default Re: ramps (KyleBst264)
Agree. A 2x4 or 2x6 in front of the ramps gives just enough clearance to keep the spoiler from rubbing.
To ramps
